Bottom up Z level Profile
Im working on a big titanium job and wanted to work my way up the part with the side of the ball endmill instead of down with the bottom.
I figured out that if you set your cut direction to conventional cut and use toolpath edit > reverse you will get a climb cut from the bottom up. I figured I'd share the tip with you guys!
Dennis Rathi
Creations Unlimited
