Bounding Block
Hello All,
I am using a bounding block for my stock.  How do I make it visible so I can attach a MCS to it?
Thanks!
FMJ
Re: Bounding Block
The bounding block in the Workpiece blank is not an actual solid body.
To define the MCS relative to the blank, you need to define the blank as a solid first.
Go to modelling and look for "Create Box" with the command finder. (Note this will be available directly from CAM soon)
There are also several older GRIP and VB programs available for this - just search the forum.
Mark Rief
Retired Siemens
Re: Bounding Block
Thank you!
