CAM-Task-Attributes ???
Hello!
Does anyone know, whether it's possible to get the "CAM Task Attributes" form "CAM Task Properties" in the postprocessor? I would like to get it.
Thank you in advance.
Werner
Werner
Production: NX10.0.3, FBM | TcUA 10.1.2.2
Development: VB.NET, Tcl/Tk | Testing: NX12.0
Re: CAM-Task-Attributes ???
Maybe :
MOM_set_attribute
help attribute post builder
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
When you post-process and enable the review option, does the attribute exist in the review or debug text files created in the folder of the opened part file?
All the part and CAM object attributes are available as mom variables. Turn on the review tool and look for mom_attr_*
Mark Rief
Retired Siemens
I need the other way. I've declared an attribute in NXCAM and want to read it in PP. The Help shows how to add atributes from PP to NXCAM.
Werner
The attributes I've declared in NXCAM are not shown in review. Other attributes are shown:
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(12): Var: mom_attr_PART_NX_Material = 16MnCr5SVA(1.7131)
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(14): Var: mom_attr_PART_GROB_REVISION = 0
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(16): Var: mom_attr_PART_NX_NON_MASTER = CAM
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(18): Var: mom_attr_PART_DB_PART_MFKID = D1951521
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(20): Var: mom_attr_PART_NX_MaterialMissingAssignments = FALSE
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(22): Var: mom_attr_PART_NX_MaterialMultipleAssigned = FALSE
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(24): Var: mom_attr_PART_GROB_OWNING_GROUP = cam
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(26): Var: mom_attr_PART_GROB_OWNING_USER = Seeger Werner
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(28): Var: mom_attr_PART_GROB_SPEC_NAME = cam_g5503_setup01/0
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(30): Var: mom_attr_PART_GRPVRSN = attribute_aendern VNX2.0.0 (build 030716),1
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(32): Var: mom_attr_PART_GROB_CATALOG_TOOL = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(34): Var: mom_attr_PART_GROB_SUPPLIER_PART = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(36): Var: mom_attr_PART_GROB_STANDARD = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(38): Var: mom_attr_PART_GROB_PNEUM_HYD = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(40): Var: mom_attr_PART_GROB_EL_MECH = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(42): Var: mom_attr_PART_GROB_ELECTRICAL = NO
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(44): Var: mom_attr_PART_GROB_MECHANICAL = YES
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(46): Var: mom_attr_PART_GROB_DES2 = .
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(48): Var: mom_attr_PART_GROB_DES1 = .
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(50): Var: mom_attr_PART_GROB_SUPPLIER = .
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(52): Var: mom_attr_PART_DB_SEED_PART_USED = cam_g5503_setup01/0
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(54): Var: mom_attr_PART_DB_SYNCHRONIZED_PARTS_LIST = SynchronizedPartsList
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(56): Var: mom_attr_PART_DB_PART_DESC = D1951521
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(58): Var: mom_attr_PART_DB_PART_NO = D1951521
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(60): Var: mom_attr_PART_DB_PART_REV = 0
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(62): Var: mom_attr_PART_DB_PART_NAME = D1951521
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(64): Var: mom_attr_PART_DB_PART_TYPE = MENCMachining
C:\Temp\D1951521_1\ptp\minussp_d7.9_bt108\grob_g5503_s840d\seeger133500_debug.out(446): Var: mom_attr_OPER_GENERATED_ON = NX 10.0.3.5 2017/02/03 13:30:57
Werner
Please note: THe attributes are different. The attributes I see in PP are:
The attribute I don't see in PP is:
Werner
I have some experience for postprocessor with access to all part attributes. When postprocessor start, start my UGOPEN application and read some attributes from prt. Or, if needed atribute empty - PP can create new attribute and save prt with new attributes (special info about part, user, CNC machine shop flor ID, etc., etc.)
I have some experience for postprocessor with access to all part attributes. When postprocessor start, start my UGOPEN application and read some attributes from prt. Or, if needed atribute empty - PP can create new attribute and save prt with new attributes (special info about part, user, CNC machine shop flor ID, etc., etc.)Part_Att.png
If you select the NC_PROGRAM node to post-process, the attributes should be visible.
If I remember correctly, only program group attributes of the selected program group are visible not of parents, but you will have to do some testing.
