CAM
Hi Any Body,
Does FBM can support for Plunging cutting process?
If yes how to make customization in MKE?
Thank you
Re: CAM
Hello dw89mk,
thank you for your question.
MKE does support Plunge Milling. You can use/ customize it like a regular Cavity Mill operation.
The only restriction that there is, you can't use Trim Boundaries and have to work with Cut Area.
If there are any further questions on this topic, please let us know.
Cheers,
Alexander
