CSE - Asynchronous HasAsyncTaskFinished - NX10.03 MP13 - 840D
Hello everybody,
I have a new strange problem.
To realize an asynchronous axis clamping time I use the asynchronous delay command.
Before the axis is moving with POS, I check the delay time with has HasAsyncTaskFinished.
For 1 time in one line it works, but not in the second line. The HasAsyncTaskFinished result is always TRUE.
Is there another method to set asynchronous clamping delays?
Best wishes from Hamburg
Viktor
1 REPLY
Re: CSE - Asynchronous HasAsyncTaskFinished - NX10.03 MP13 - 840D
Hello again,
the return command for the async Motion has to be the HasAsyncTaskFinished. Now it works.
