CSE - CALL LBL
Hi everybody,
what is important to use CALL LBL "TEXT" while simulating with CSE?
If I take a NC Code with CALL LBL it works.
Could it be a problem with the postprocessor?
Thanks!
Best regards
Viktor
1 REPLY 1
Re: CSE - CALL LBL
This Problem was solved. The following syntax from the posprocessor was the reason: MOM_output_text "\nLBL \"RESET\""
Change this into that:
MOM_output_text " "
MOM_output_text "LBL \"RESET\""
and the Problem is solved....
Best regards
Viktor
