CSE CYCLE800 error: Program name '_DEC1' not found. (line: 56, program: CYCLE800, channel: CHAIN)
Hello
I'm making a CSE simulation based on SIM09.
Machine is idenical whit SIM09 kinematics.
Kinematics are defined in Machine tool configuration.
Program line:
CYCLE800()
causes this error:
Any idea What is causing this?
Re: CSE CYCLE800 error: Program name '_DEC1' not found. (line: 56, program: CYCLE800, channel: CHAIN
Please make sure you have also copy the needed subprogs. In that case the cyc file from sim09
SinumerikSL_Cycles.cyc
..MACH\resource\library\machine\installed_machines\sim09_mill_5ax\cse_driver\sinumerik\subprog
That file includes definition subprograms which are needed inside CYCLE800.
The related subprograms are loaded via the ini file in sim09
sim09_mill_5ax-Main.ini
SMAC
PGUD
TC_CARR
Thomas Schulz
Siemens PLM
Hello
Got Solved.
Kinematic chain name was different in model than in MCF file (GV_strSwivelingChainName).
