CSE. Change the tool trace point.
Hello everybody, the question I have is, how can I change the point where NX outputs the trace when I select "Show tool trace" option in the simulation.
Frank.
Re: CSE. Change the tool trace point.
No there is no special setting for that.
There is one single rule.
The system will use the tool tip of the first tracking point of the active tool in the carrier.
We are in the progress of enhance it to have an active tracking point
So at the end the NC code and the related driver define where the tool trace appears.
Thomas Schulz
Siemens PLM
