CSE: Error Tool 1 not defined in tool data table.
Hello
can someone tell me what the reason for this error message is and how I can fix it
Thanks a lot.
NX11.0.2.7 MP4
Re: CSE: Error Tool 1 not defined in tool data table.
the reason is quite obvious as the message explain that the tool data is missing. You found the reason. How to solve: Make sure the ini file is up to date and includes all needed tool data. When running internal NC code simulation based on operations the post of the OOTB data will create a proper to_ini.ini file.
I assume the NC code will simulate T1 M6.
Hope it helps
Thomas Schulz
Siemens PLM
