CSE PLANE SPATIAL 5 axis problem
Hello Everyone,
I'm trying to make simulation for Hermle C30U 5axis with Heidenhein controller and as my example I'm using sim08_mill_5ax_tnc. Tool path simulation works good but when I start machine code simulation first operation without rotaion work perfect, but there is problem in second operation with PLANE SPATIAL. Machine rotate axis C instead of Axis A and the tool position is in wrong place. Maybe there is something wrong in my kinematic model?
Best regards,
