CSE Parser Error - CYCL DEF 32.2 HSE-MODE:1
Getting a parser error when I run simulation using Machine Code Simulation.  Using heidenhainTNC cse_driver from sim14_mill_5ax .
Post processed code snippet:
822 CYCL DEF 32.0 TOLERANCE
823 CYCL DEF 32.1
824 CYCL DEF 32.2 HSC-MODE:1
Can anyone provide suggestion on what to add/modify in HeidenhainTNC.CCF file?
HeidenhainTNC.CCF file currently has CYCL_DEF_32  defined:
Thank you for your time.
Re: CSE Parser Error - CYCL DEF 32.2 HSE-MODE:1
Hi Quaffe,
you have to add parameters to the CYCL DEF lines as described in the TNC manual.
CYCL DEF 32.1 T0.04
CYCL DEF 32.2 HSC-MODE:1 TA5
I added T0.04 and TA5 exemplarily.
ThomasF
Thank you Thomas!
