CSE Simulation error
Since I installed the last QRM (10.0.3), I have an error when I simulate with a custom machine.
Before the update this error doens´t exists.
Failure happens when i finish a simulation.
Anybody knows why is this error happening¿?
Ivan
Re: CSE Simulation error
please check if you have sub folders on the disc in the "subprog" folder where CSE searches for subprograms.
e.g.
..mach\resource\library\machine\installed_machines\sim09_mill_5ax\cse_driver\fanuc\subprog
or / and
..mach\samples\nc_simulation_samples\cse_files\subprog
the folder should contain subprogram files only.
If that fixes it it is a known topic and is fixed in MP1 for NX10.0.3
Thomas Schulz
Siemens PLM
