CSE - $TC_CARR37
Hello everybody,
I have a new problem with CYCLE800.
While the nc code simulation I get the following message:
ALARM: 61019 $TC_CARR37[1] DEC4
For this alarm code I do not get a real definition in connection with CYCLE800 and the identifier.
So, what could it be?
Best regards
Viktor
Re: CSE - $TC_CARR37
What kind of motion? Cycle? Linear?
I remember a same, problem in my case was in cycles drilling parameters...
this problem causes while starting the CYCLE800.
Are you try it?
thank you very much, you are right with this document.
I solved my problem some days ago.
The preferred direction of the rotary axes was set to "8". I dont know why...
Setting down this element clears the problem.
Best wishes from Hamburg
Viktor
