CSE. $TX_TRAFO
Morning!
My programm for simulation include a lot of TRANSMIT command. But after 10 TRANSMIT I see a message - SetArrayElement with wrong argument.
TRANSMIT try to set $TX_TRAFO[11], but in CCF dimension of this array 10 only. Ok, I change dimension fo $TX_TRAFO to 100, save all CCF MCF - reopen - DIMENSION of $TX_TRAFO is 10!!! Why?!
Re: CSE. $TX_TRAFO
Hi YuriThomas,
Somtimes there is a bug in the Machine Configurator. Please try this way.
- Open MCF in MC
- Add Variable
- Save it
- Close MC
- Reopen it --> now the dimension should be correct
Let me know if it helps.
ThomasF
