CSE Transformations
I have problem with coordinate rotation.
I have my own coordinate rotation command that rotates "ROTATIONAL" transformation.
Same time when coordinate system is rotated machine axis jump, but not with coordinate system.
Im lookin offsets of all tranformations including "ROTATIONAL".
None of transformation ofsetts changes.
How can I debug tranformation so that I can see if its rotated and how this rotation effects other transformations?
Currently Im using; getTrafoOffset("ROTATIONAL",getFirstGeoAxis () ) look at offsets.
But how I can see other info from tranformations?
Re: CSE Transformations
I narrowed problem down to a tranformation.
Activating this empty transformation will cause jump in machine axis, why?
I made new command that reset transformation and activates it.
It does not offset or rotate, it just reset and activate, how or why this causes Xaxis to jump?
This jump is Xaxis only, this jump is not offset for any transformation.
If X axis is commanded again to same place that it was before jump it will take orginal position.
Any idea what could cause this?
Hello Jussi,
About the "jump" I need to discuss internally.
Here some more CSE methods to get details out of transformations, if you didn't know already.
Thomas Schulz
Siemens PLM
