CSE - UGII variables
Is there a way of determining the value of NX system variables from within CSE?
For example, UGII_TMP_DIR?
Re: CSE - UGII variables
not that I am aware of. There is no way of request environment variables from XML.
There is maybe a possibility to customize something with the Python parser (today not available for Sinumerik) and set an CSE variable which can be used in XML, but I do not know any details of that; for sure more a programming topic.
Thomas Schulz
Siemens PLM
