CSE: boring simulation on a milling machine
Hi all! And happy new year!
I use standard "sim03" (Sinumerik).
I want to simulate a rotation of usual boring tool (on a milling 4-axis machine).
But I can't figure out how to do it. Solid milling tools rotate normally during simulation.
Thank you for either help!
I found a similar video of my need here:
https://www.youtube.com/watch?v=0QtSQ5sXP8c
Re: CSE: boring simulation on a milling machine
Thank you, Thomas!
However, I only need to set the visual rotation of the cutter, as in the video on YouTube (which I showed above). I even can't do this with the removal of the 3D-material (enough axial simulation in G-codes). And I have a restriction - NX 10 (as in the video from YouTube - also nx10). Customer has NX10((
I just need a visual rotation of the cutter (see my picture) with any frequency
