CSE driver DMG NZX2000
Hello everyone,
Would anyone help me modify the CSE driver for the DMG MORI NZX2000 lathe with Fanuc? I wanted to use CSE from sim13_turn_4ax, but it would be better to use CSE from sim15_millturn_9ax where it differs in the first channel. The simulation is a hinged head and the NZX2000 has a Y-axis revolver. In the Appendix I am sending PDF machines.
Thank you for any help
