CSE - loading duration
Hello everybody,
what would you say is the most reason for the loading time a machine code simulation is needed?
I tried to keep clean the cse drivers. Perhaps the postprocessor or the assembly are the reason for the loading time?
Regards, Viktor
Re: CSE - loading duration
Hi Viktor,
to find out what is more time consuming you can easily check the time when doing internal and external simulation (with and without PP) for the same group of operations/ NC Code.
Thomas
Hi Thomas,
thanks for your feedback.
I already checked it, the postprocessor is not guilty.
Regards, Viktor
