Do you mean
Reply
CSE not registered
Our customer has a machine Parpas SHARK ONE, six axes are under control (3 linear axes an 3 rotary axes – 2 of them are for head and 1 is for table), CNC is Siemens 840D. So, customer asks us whether it’s possible to create CSE-driver for the machine tool. Could you please provide any comments about that? Maybe you can recommend to use any existing CSE that we can modify, or you can provide an example of CSE for 6ax machine?
Below you can find short description of the machine tool.
More about head see http://www.youblisher.com/p/1202964-SHARK/ (page 6)
Rotary table with digital motor for milling, controlled by an axis of the NC.
http://www.gruppoparpas.com/dynamicdata/Shark.aspx
