CSE - to_ini
Hello everybody,
is it possible to set the reading path for the to_ini file?
For example not the working part path, but the C:\Temp\ISV\path?
In NX10.03 MP1 the reference $UGII_CAM_CSE_USER_DIR is not working...
Best wishes from Hamburg,
Viktor
12 REPLIES 12
Re: CSE - to_ini
Hi Victor,
the env should work. Make sure you have it like this:
$UGII_CAM_CSE_USER_DIR\subprog\to_ini.ini
Thomas
Thomas Schulz
Siemens PLM
Re: CSE - to_ini
Hi VikP,
here is an overview how the INI mechanism works.
Thomas
Re: CSE - to_ini
Hi Thomas,
thank you for the overview of the to_ini working machanism.
Now we have a customer who works with Teamcenter.
If we take the OOTB simulation_ini.tcl, then a folder named as the CAM-Part is created in C:\Temp like this:
    C:\Temp\CAM-Part\cse_files\subprog
In this folder the to_ini.ini is created and works fine with the CSE. But how works it? Does the CSE get this information from Teamcenter? Where can I customize this option?
Regards, Viktor
Re: CSE - to_ini
Hi Victor,
in case of TC we suggest to use the environment variable to place subprogram and ini files.
The latest OOTB simulation TCL file checks if that env is set and create the to_ini.ini direct on that location.
CSE later looks to the three locations to find ini files and subprograms as usual and independent of managed mode or not.
If the env is not set the ini file is written where the CAM part file is located and in case of TC that is these one shared temp folder.
Hope that helps to clarify
Thomas
Thomas Schulz
Siemens PLM
Re: CSE - to_ini
Hi everybody,
now I have again some problems with reading the to_ini.ini file. With TC and native NX - same result.
But now we use NX11 and a multichannel machine.
We're working with UGII_CAM_CSE_USER_DIR and all subprogs were involved correctly - the to_ini.ini is shown in the subprog list in Program Manager.
BUT while starting the Sync Manager or single operation, the to_ini.ini file is NOT read and I dont get the tool informations.
It looks like the to_ini.ini file is posted to late :/
Has something like this happened before?
Regards, Viktor
Re: CSE - to_ini
Hello Victor,
we have found some problems in that area. It is hard to say what the real root cause in your environment ist, but here some hints.
In NX12.0.1 MP3 we submitted fixes to problems we know.
In NX11 you can give it a try to create the ini fiels using the routine MOM_start_subroutine that can be a workaround but I can not fully confirm.
Thomas Schulz
Siemens PLM
Re: CSE - to_ini
Hi Thomas,
thanks for your feedback.
You knew that ISFILE metacode doesnt work with UGII_CAM_CSE_DIR?
I did not... but know! Smiley Happy
Now it works fine.
Regards and a gread sunny day!
Viktor
Re: CSE - to_ini
Same problem, post do not generate to_ini on start of simulation. machine: sim03_mill_4ax, SINUMERIK, NX 1859
Its should generate ini config with tools and offsets, as its shown in Working_with_OOTB_MACH_Simulation_Examples pdf , but its doesnt. Sorry for bad english.
my nc program starts like this
Spoiler
;%_N_10GM150_MPF
;(--- 17.04.2019 ---) ;
;(X0Y0 - CENTER DETALY)
;(Z0 - CENTER STOLA)
G40 G17 G71 G90
M09
 ; (--- FREZA D50B8 GRIB  ---) ;
 ; (--- B180 ---) ;
 ; (--- MESTO 7 ---) ;
T="FREZAD50"
M6
G54
B180.
S300 M3
R90=10 ;  PODACHA ZAHODA XY
R91=50 ; PODACHA VIHODA XY
R92=200 ; PODACHA BYSTRAYA
TRANS X0 Y0 Z95.5  ; (DO VERHA DETALI)
; (DO RAZMERNOY PLOSKOSTY)
G0 X0 Y0
G1 Z-40. F2000. M8
R1= -40 ; (--- Z NACHALA OBR ---) ;
Spoiler
Spoiler
SIM LOG:
The file N:\Siemens\NX\mach\resource\library\machine\installed_machines\sim03_mill_4ax\cse_driver\sinumerik\sim03_mill_4ax_sinumerik
.MCF was processed successfully.
The file N:\Siemens\NX\mach\resource\library\machine\installed_machines\sim03_mill_4ax\cse_driver\sinumerik\Siemens840D.CCF was proc
essed successfully.
The file N:\Siemens\NX\mach\resource\library\machine\installed_machines\sim03_mill_4ax\cse_driver\sinumerik\Basic.CCF was processed
successfully.
Program file N:\NC PROGRAMS\10GM150\10GM150.MPF in use
IPW created for 'BLANK'. Needle count 500 Needle distance 0.42885772
FULL LOG:
Using ugii_env.dat file from N:\Siemens\NX\UGII
 Using MFGViewMaker_env.dat file from N:\Siemens\NX\DRAFTING\manifest\MFGViewMaker_env.dat
 Using automotive_env.dat file from N:\Siemens\NX\UGAUTOMOTIVE\manifest\automotive_env.dat
 Using moldwizard_env.dat file from N:\Siemens\NX\MOLDWIZARD\manifest\moldwizard_env.dat
 Using stampingtools_env.dat file from N:\Siemens\NX\STAMPING_TOOLS\manifest\stampingtools_env.dat
 Using design_tools_env.dat file from N:\Siemens\NX\DESIGN_TOOLS\manifest\design_tools_env.dat
 Using Mechatronics_player_env.dat file from N:\Siemens\NX\MECHATRONICS\manifest\Mechatronics_player_env.dat
 Using ugphoto_env.dat file from N:\Siemens\NX\UGPHOTO\manifest\ugphoto_env.dat
 Using cam_env.dat file from N:\Siemens\NX\MACH\manifest\cam_env.dat
 Using ToolDesigner_env.dat file from N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\ToolDesigner_env.dat
 Using animation_designer_env.dat file from N:\Siemens\NX\MECHATRONICS\manifest\animation_designer_env.dat
 Using pcb_env.dat file from N:\Siemens\NX\UGPCBXCHANGE\manifest\pcb_env.dat
 Using rout_env.dat file from N:\Siemens\NX\ROUTING\manifest\rout_env.dat
 Using mlp_env.dat file from N:\Siemens\NX\MACH\manifest\mlp_env.dat
 Using LineDesigner_env.dat file from N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\LineDesigner_env.dat
 Using mpa_env.dat file from N:\Siemens\NX\MPA\manifest\mpa_env.dat
 Using texture_modeling_env.dat file from N:\Siemens\NX\UGII\manifest\texture_modeling\texture_modeling_env.dat
 Using PressLineSimul_env.dat file from N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\PressLineSimul_env.dat
 Using fpcd_env.dat file from N:\Siemens\NX\UGFPCD\manifest\fpcd_env.dat
 Using AutomationDesigner_env.dat file from N:\Siemens\NX\AUTOMATION_DESIGNER\manifest\AutomationDesigner_env.dat
 Using TDP_env.dat file from N:\Siemens\NX\TDP\manifest\TDP_env.dat
 Using aerostructures_env.dat file from N:\Siemens\NX\SIMULATION\manifest\aerostructures\aerostructures_env.dat
 Using mechatronics_env.dat file from N:\Siemens\NX\MECHATRONICS\manifest\mechatronics_env.dat
 Using additive_manufacturing_env.dat file from N:\Siemens\NX\MACH\manifest\additive_manufacturing_env.dat
 Using PID_env.dat file from N:\Siemens\NX\DIAGRAMMING\manifest\PID_env.dat
 Using drafting_env.dat file from N:\Siemens\NX\DRAFTING\manifest\drafting_env.dat
 Using weld_env.dat file from N:\Siemens\NX\UGWELD\manifest\weld_env.dat
 Using nx_realize_shape_env.dat file from N:\Siemens\NX\UGII\manifest\nx_realize_shape\nx_realize_shape_env.dat
 Using polygon_modeling_env.dat file from N:\Siemens\NX\UGII\manifest\polygon_modeling\polygon_modeling_env.dat
 Using nxship_env.dat file from N:\Siemens\NX\NXSHIP\manifest\nxship_env.dat
 Using dmu_env.dat file from N:\Siemens\NX\UGII\manifest\dmu\dmu_env.dat
 Using hm_env.dat file from N:\Siemens\NX\NXHUMAN\manifest\hm_env.dat
 Using cmm_inspection_env.dat file from N:\Siemens\NX\CMM_INSPECTION\manifest\cmm_inspection_env.dat
 Using cae_env.dat file from N:\Siemens\NX\SIMULATION\manifest\cae_env.dat
 Using environment file N:\Siemens\NX\ugii\ugii_env_ug.dat
 UGII_JAVA_HOME was set from registry hive HKEY_LOCAL_MACHINE\SOFTWARE\JavaSoft\Java Runtime Environment\1.8
 ************** Unlocked NX Configuration Variables **************
   [18] AEROSTRUCTURES_APP_DIR           N:\Siemens\NX\simulation\aerostructures
   [29] ANIMATION_DESIGNER_APP_DIR       N:\Siemens\NX\mechatronics\animation_designer
   [20] AUTOMATION_DESIGNER_APP_DIR      N:\Siemens\NX\automation_designer
   [37] AUTOMOTIVE_APP_DIR               N:\Siemens\NX\ugautomotive;N:\Siemens\NX\ugautomotive\bodydes;N:\Siemens\NX\ugautomotive\diedes;N:\Siemens\NX\ugautomotive\dieeng;N:\Siemens\NX\ugautomotive\packaging
    [4] AUTOSTAMPING_DATA_DIR            N:\Siemens\NX\ugautomotive\diedes
   [31] CAM_APP_DIR                      N:\Siemens\NX\mach
    [7] CMM_INSPECTION_APP_DIR           N:\Siemens\NX\cmm_inspection
   [34] DESIGN_TOOLS_APP_DIR             N:\Siemens\NX\design_tools
    [9] DMU_APP_DIR                      N:\Siemens\NX\ugii\dmu
   [14] DRAFTING_APP_DIR                 N:\Siemens\NX\drafting
    [4] DXFDWG_DIR                       N:\Siemens\NX\dxfdwg\
    [4] EDIEWIZARD_DIR                   N:\Siemens\NX\stamping_tools\ediewizard
    [4] EDIEWIZARD_LIB_DIR               N:\Siemens\NX\stamping_tools\ediewizard
    [4] ELECTRODE_DESIGN_DIR             N:\Siemens\NX\moldwizard\electrode
   [21] FPCD_APP_DIR                     N:\Siemens\NX\ugfpcd
    [4] GC_TOOL_DIR                      N:\Siemens\NX\localization\\gc_tools
    [4] GEARWIZARD_DIR                   N:\Siemens\NX\localization\\GearWizard
    [4] HOME                             C:\Users\pass321\AppData\Local\Temp
    [4] IGES_DIR                         N:\Siemens\NX\iges\
    [4] JK_KIT                           N:\Siemens\NX\nxhuman\jack_toolkit
    [4] JK_KIT_DEV                       N:\Siemens\NX\nxhuman\jack_toolkit
    [4] JK_KIT_PLATFORM                  nt4
   [25] LINE_DESIGNER_APP_DIR            N:\Siemens\NX\manufacturing_planning\line_designer
    [4] LMSDurMessagePath                N:\Siemens\NX\simulation\durspecialist\Resources
    [4] MAYA_PCB_DIR                     N:\Siemens\NX\ugpcbxchange
   [17] MECHATRONICS_APP_DIR             N:\Siemens\NX\mechatronics
   [33] MECHATRONICS_PLAYER_APP_DIR      N:\Siemens\NX\mechatronics\player
   [38] MFG_VIEW_MAKER_APP_DIR           N:\Siemens\NX\drafting\mfg_view_maker
   [26] MLP_APP_DIR                      N:\Siemens\NX\mach\mlp
   [36] MOLDWIZARD_APP_DIR               N:\Siemens\NX\moldwizard
    [4] MOLDWIZARD_DIR                   N:\Siemens\NX\moldwizard
    [4] MOLDWIZARD_LIB_DIR               N:\Siemens\NX\moldwizard
   [24] MPA_APP_DIR                      N:\Siemens\NX\mpa
    [4] NXCHECKMATE_LOCALIZATION_DIR     N:\Siemens\NX\design_tools\checkmate\localization
    [4] NXDESIGNTOOLS_DIR                N:\Siemens\NX\design_tools
    [8] NXHUMAN_APP_DIR                  N:\Siemens\NX\nxhuman
    [4] NXISSUETRACKING_DIR              N:\Siemens\NX\design_tools\issue_tracking
    [4] NXREPORTS_DIR                    N:\Siemens\NX\nxreports
    [4] NXREQUIREMENT_DIR                N:\Siemens\NX\design_tools\requirement
   [10] NXSHIP_APP_DIR                   N:\Siemens\NX\nxship
    [4] NXSHIP_CONFIG_DIR                N:\Siemens\NX\nxship\data
    [4] NXSHIP_DIR                       N:\Siemens\NX\nxship
    [4] NXSHIP_GSD_DIR                   N:\Siemens\NX\nxship\shipgsd
    [4] NXSHIP_NUMBER                    S3522
    [4] NXSHIP_STDPART_DIR               N:\Siemens\NX\nxship\StandardPart
    [4] NXSHIP_STEELFEATURE_DIR          N:\Siemens\NX\nxship\data\steelfeature
    [4] NXVISUALREPORTING_DIR            N:\Siemens\NX\nxreports\visual_reporting
    [4] NX_APPLY_VISMAT_TO_BODIES_OF_COMP 1
   [11] NX_POLYGON_MODELING_DIR          N:\Siemens\NX\ugii\polygon_modeling
   [12] NX_REALIZE_SHAPE_DIR             N:\Siemens\NX\ugii\nx_realize_shape
    [4] NX_RTS_IRAY                      1
   [23] NX_TEXTURE_MODELING_DIR          N:\Siemens\NX\ugii\texture_modeling
    [4] OT_PUB_APPLICATION_DIR           N:\Siemens\NX\pvtrans\ot_pub
    [3] PATH                             C:\Program Files\Java\jre1.8.0_211\bin;N:\Siemens\NX\nxbin;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\
    [1] PATHEXT                          .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
   [28] PCB_APP_DIR                      N:\Siemens\NX\ugpcbxchange
    [4] PDIEWIZARD_DIR                   N:\Siemens\NX\stamping_tools\pdiewizard
    [4] PDIEWIZARD_LIB_DIR               N:\Siemens\NX\stamping_tools\pdiewizard
   [15] PID_APP_DIR                      N:\Siemens\NX\diagramming\pid
   [15] PID_GENERIC_INSTRUMENT_NOZZLE    N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Nozzles\General_instrument_nozzle\General_instrument_nozzle.xml
   [15] PID_GENERIC_INSTRUMENT_PIPING_TEE N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Tees\Instrument_piping_equal_tee\Instrument_piping_equal_tee.xml
   [15] PID_GENERIC_INSTRUMENT_TEE       N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Tees\Instrument_equal_tee\Instrument_equal_tee.xml
   [15] PID_GENERIC_NOZZLE               N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Nozzles\General_nozzle\General_nozzle_metric.xml
   [15] PID_GENERIC_TEE                  N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Tees\Equal_tee\Equal_tee.xml
   [15] PID_INSTRUMENTATION_DIR          N:\Siemens\NX\diagramming\pid\library\contents/metric/PID_Parts/Instrumentation;N:\Siemens\NX\diagramming\pid\library\contents/inch/Instrumentation
   [15] PID_LIBRARY_CONFIG_FILE          N:\Siemens\NX\diagramming\pid\library\Configure\PIDReuseLibraryConfiguration.krx
   [15] PID_LIBRARY_DIR                  N:\Siemens\NX\diagramming\pid\library\contents
   [15] PID_LIBRARY_INSTALL_TOOL         N:\Siemens\NX\diagramming\pid\library\InstallTool
   [15] PID_LINE_TYPE_DIR                N:\Siemens\NX\diagramming\pid\library\contents\LineTypes
   [15] PID_NOZZLE_DIR                   N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Nozzles;N:\Siemens\NX\diagramming\pid\library\contents\inch\Fittings\Nozzles
   [15] PID_PIPE_STOCK_DIR               N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Stocks\DIN_BW_Pipe;N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Stocks\DIN_Steel;N:\Siemens\NX\diagramming\pid\library\contents\inch\PipeStocks
   [15] PID_SPECIFICATION_DIR            N:\Siemens\NX\diagramming\pid\library\contents\Specifications
   [15] PID_TEE_DIR                      N:\Siemens\NX\diagramming\pid\library\contents\metric\PID_Parts\Fittings\Tees;N:\Siemens\NX\diagramming\pid\library\contents\inch\Fittings\Tees
   [22] PRESS_LINE_SIMULATION_APP_DIR    N:\Siemens\NX\manufacturing_planning\pressline_simulation
   [22] PRESS_LINE_SIMULATION_APP_PRESSLINES_DIR N:\Siemens\NX\manufacturing_planning\pressline_simulation\resources\presslines
   [22] PRESS_LINE_SIMULATION_APP_RESOURCE_DIR N:\Siemens\NX\manufacturing_planning\pressline_simulation\resources
   [22] PRESS_LINE_SIMULATION_APP_SETUP_TEMPLATES_DIR N:\Siemens\NX\manufacturing_planning\pressline_simulation\resources\setup_templates
    [4] PVTRANSUI_DIR                    N:\Siemens\NX\pvtrans
    [4] PYTHONPATH                       N:\Siemens\NX\nxbin\python;N:\Siemens\NX\nxbin\python\Python37.zip;N:\Siemens\NX\nxhuman\jack_toolkit\lib;N:\Siemens\NX\nxhuman\jack_toolkit\library\script
    [4] QUICKSTACK_DIR                   N:\Siemens\NX\tolstackup\ugquickstack
   [27] ROUTING_APP_DIR                  N:\Siemens\NX\routing
   [34] SHAPESEARCH_JAR_DIR              N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer
    [6] SIMULATION_APP_DIR               N:\Siemens\NX\simulation
    [4] SPLM_DIAGRAM_DIR                 N:\Siemens\NX\diagramcore
    [1] SPLM_LICENSE_SERVER              28000@LocalHost
   [35] STAMPINGTOOLS_APP_DIR            N:\Siemens\NX\stamping_tools
    [4] STEP203UG_DIR                    N:\Siemens\NX\step203ug\
    [4] STEP214UG_DIR                    N:\Siemens\NX\step214ug\
    [4] STEP242_DIR                      N:\Siemens\NX\translators\step242\
   [19] TDP_APP_DIR                      N:\Siemens\NX\tdp
    [1] TEMP                             C:\Users\pass321\AppData\Local\Temp
    [1] TMP                              C:\Users\pass321\AppData\Local\Temp
    [4] TOLSTACKUP_DIR                   N:\Siemens\NX\tolstackup
    [4] TOOLING_BASE_DIR                 N:\Siemens\NX\tooling_base
   [30] TOOL_DESIGNER_APP_DIR            N:\Siemens\NX\manufacturing_planning\fixture_planner
    [4] UF_MF_PA_FACET_TOL               0.05
    [4] UF_MF_PA_MAX_EDGE                10.0
    [4] UF_MF_PA_PATH                    C:\moldflow\mpa300\bin
    [4] UF_MF_PA_STL_DIR
    [4] UF_MF_PA_STL_SUF                 slp
    [4] UGALLIANCE_DIR                   N:\Siemens\NX\ugalliance
    [4] UGAUTOMOTIVE_DIR                 N:\Siemens\NX\ugautomotive
    [4] UGBODYDES_DIR                    N:\Siemens\NX\ugautomotive\bodydes
   [20] UGCHECKMATE_COLUMN_CONFIGURATION_FILE N:\Siemens\NX\automation_designer\samples\MassIssueReportingColumnConfiguration.xml
    [4] UGCHECKMATE_CONFIG               N:\Siemens\NX\design_tools\checkmate\customization\ugcheckmate.dat
    [4] UGCHECKMATE_DIR                  N:\Siemens\NX\design_tools\checkmate
    [2] UGCHECKMATE_HIDE_CHECKER         %mqc_report_blanked_entity
    [4] UGCHECKMATE_MENU_TEMPLATE_FILE   N:\Siemens\NX\design_tools\checkmate\templates\user_defined_menu_template.txt
    [4] UGCHECKMATE_XMLLOG_XSL_FILE      N:\Siemens\NX\design_tools\checkmate\examples\checkmate_log.xsl
    [4] UGDIEDES_DIR                     N:\Siemens\NX\ugautomotive\diedes
    [4] UGDIEDES_STANDARD_DIR            N:\Siemens\NX\ugautomotive\diedes
    [4] UGDIEENG_DIR                     N:\Siemens\NX\ugautomotive\dieeng
    [4] UGII_08_FILE                     N:\Siemens\NX\ugopen\08.ugf
    [4] UGII_10_FILE                     N:\Siemens\NX\ugii\10.ugf
    [4] UGII_3DCONNEXION_LIBRARY         \v1847\startup\3DxNX.dll
    [4] UGII_ABAQUS                      C:\Program Files\abaqus\win\6.6-2\exec\abq662.exe
    [4] UGII_ABAQUS_VERSION              6.6
   [16] UGII_ADDITIVE_MANUFACTURING_INSTALLED_PRINTERS_DIR N:\Siemens\NX/mach/resource/library/machine/installed_machines
   [20] UGII_AD_EDITOR_DIR               N:\Siemens\NX\automation_designer\amecodeeditor
    [4] UGII_AFM_DIR                     N:\Siemens\NX\nxcae_extras\afm
    [4] UGII_AMSIMULATION_ALPHA_DATABASE N:\Siemens\NX\simulation\am_simulation\application\Data\parameters.xml
    [4] UGII_AMSIMULATION_ALPHA_SUPPORTMATERIAL_DATABASE N:\Siemens\NX\simulation\am_simulation\application\Data\parameters_support.xml
    [4] UGII_AMSIMULATION_DIR            N:\Siemens\NX\simulation\am_simulation
    [4] UGII_ANNOTATION_TEMPLATE_DIR     N:\Siemens\NX\ugii\inh_files\
    [4] UGII_ANSYS                       C:\Program Files\ansys_inc\ansys100\win\v100\ANSYS\bin\intel\ansys100.exe
    [4] UGII_ANSYS_PRODUCT               ansys
    [4] UGII_ANSYS_VERSION               19
    [4] UGII_APT_VOC                     N:\Siemens\NX\mach\auxiliary\apt.voc
    [1] UGII_BASE_DIR                    N:\Siemens\NX
    [4] UGII_BCL_VOC                     N:\Siemens\NX\mach\auxiliary\bcl.voc
    [4] UGII_CAE_AFUAPP                  N:\Siemens\NX\ugstructures\ftk\afuapp.jar
    [4] UGII_CAE_POST_TEMPLATE_USER_DIR  C:\Users\pass321\AppData\Local\Temp\post_template_files
    [4] UGII_CAE_REPORT_TEMPLATES_DIR    N:\Siemens\NX\UGSTRUCTURES\
    [4] UGII_CAMBATCH_BACKGROUND_EXE     N:\Siemens\NX\mach\auxiliary\batch\cambatch_background.exe
    [4] UGII_CAM_AUXILIARY_DIR           N:\Siemens\NX\mach\auxiliary\
    [4] UGII_CAM_BASE_DIR                N:\Siemens\NX\mach\
    [4] UGII_CAM_BATCH_DIR               N:\Siemens\NX\mach\auxiliary\batch\
    [4] UGII_CAM_CONFIG                  N:\Siemens\NX\mach\resource\configuration\cam_general.dat
    [4] UGII_CAM_CONFIG_DIR              N:\Siemens\NX\mach\resource\configuration\
    [4] UGII_CAM_CUSTOM_DIR              N:\Siemens\NX\mach\custom\
    [4] UGII_CAM_DEBUG_DIR               N:\Siemens\NX\mach\resource\debug\
    [4] UGII_CAM_DEFAULT_TYPE_TEMPLATE   N:\Siemens\NX\mach\resource\template_set\cam_general.opt
    [4] UGII_CAM_FEATURE_DATA_DIR        N:\Siemens\NX\mach\resource\feature\
    [4] UGII_CAM_FEATURE_DATA_ENGLISH_DIR N:\Siemens\NX\mach\resource\feature\english\
    [4] UGII_CAM_FEATURE_DATA_METRIC_DIR N:\Siemens\NX\mach\resource\feature\metric\
    [4] UGII_CAM_FEATURE_IMAGES_DIR      N:\Siemens\NX\mach\resource\feature\images\
    [4] UGII_CAM_FILE_SEARCH_PATH        .\;N:\Siemens\NX\mach\;N:\Siemens\NX\mach\resource\
    [4] UGII_CAM_IMAN_TYPE_TEMPLATE      N:\Siemens\NX\mach\resource\template_set\cam_teamcenter_general.opt
    [4] UGII_CAM_LIBRARY_DEVICE_ASCII_DIR N:\Siemens\NX\mach\resource\library\device\ascii\
    [4] UGII_CAM_LIBRARY_DEVICE_DATA_DIR N:\Siemens\NX\mach\resource\library\device\ascii\
    [4] UGII_CAM_LIBRARY_DEVICE_DIR      N:\Siemens\NX\mach\resource\library\device\
    [4] UGII_CAM_LIBRARY_DEVICE_GRAPHICS_PATH N:\Siemens\NX\mach\resource\library\device\graphics\
    [4] UGII_CAM_LIBRARY_DEVICE_INCLASS_DIR N:\Siemens\NX\mach\resource\library\device\inclass\
    [4] UGII_CAM_LIBRARY_DIR             N:\Siemens\NX\mach\resource\library\
    [4] UGII_CAM_LIBRARY_FEEDS_SPEEDS_ASCII_DIR N:\Siemens\NX\mach\resource\library\feeds_speeds\ascii\
    [4] UGII_CAM_LIBRARY_FEEDS_SPEEDS_DATA_DIR N:\Siemens\NX\mach\resource\library\feeds_speeds\ascii\
    [4] UGII_CAM_LIBRARY_FEEDS_SPEEDS_DIR N:\Siemens\NX\mach\resource\library\feeds_speeds\
    [4] UGII_CAM_LIBRARY_FEEDS_SPEEDS_GENIUS_DIR N:\Siemens\NX\mach\resource\library\feeds_speeds\genius\
    [4] UGII_CAM_LIBRARY_FEEDS_SPEEDS_INCLASS_DIR N:\Siemens\NX\mach\resource\library\feeds_speeds\inclass\
    [4] UGII_CAM_LIBRARY_INSTALLED_MACHINES_DIR N:\Siemens\NX\mach\resource\library\machine\installed_machines\
    [4] UGII_CAM_LIBRARY_MACHINE_ASCII_DIR N:\Siemens\NX\mach\resource\library\machine\ascii\
    [4] UGII_CAM_LIBRARY_MACHINE_CONFIG_DIR N:\Siemens\NX\mach\resource\postprocessor\
    [4] UGII_CAM_LIBRARY_MACHINE_DATA_DIR N:\Siemens\NX\mach\resource\library\machine\ascii\
    [4] UGII_CAM_LIBRARY_MACHINE_DIR     N:\Siemens\NX\mach\resource\library\machine\
    [4] UGII_CAM_LIBRARY_MACHINE_GENIUS_DIR N:\Siemens\NX\mach\resource\library\machine\genius\
    [4] UGII_CAM_LIBRARY_MACHINE_GRAPHICS_PATH N:\Siemens\NX\mach\resource\library\machine\graphics\
    [4] UGII_CAM_LIBRARY_MACHINE_INCLASS_DIR N:\Siemens\NX\mach\resource\library\machine\inclass\
    [4] UGII_CAM_LIBRARY_TEMPLATE_DATA_DIR N:\Siemens\NX\mach\resource\template_dir\
    [4] UGII_CAM_LIBRARY_TEMPLATE_DIR    N:\Siemens\NX\mach\resource\template_dir\
    [4] UGII_CAM_LIBRARY_TOOL_ASCII_DIR  N:\Siemens\NX\mach\resource\library\tool\ascii\
    [4] UGII_CAM_LIBRARY_TOOL_ASCII_LOAD_LIMIT 100000
    [4] UGII_CAM_LIBRARY_TOOL_DIR        N:\Siemens\NX\mach\resource\library\tool\
    [4] UGII_CAM_LIBRARY_TOOL_ENGLISH_DIR N:\Siemens\NX\mach\resource\library\tool\english\
    [4] UGII_CAM_LIBRARY_TOOL_GENIUS_DIR N:\Siemens\NX\mach\resource\library\tool\genius\
    [4] UGII_CAM_LIBRARY_TOOL_GRAPHICS_PATH N:\Siemens\NX\mach\resource\library\tool\graphics\
    [4] UGII_CAM_LIBRARY_TOOL_INCLASS_DIR N:\Siemens\NX\mach\resource\library\tool\inclass\
    [4] UGII_CAM_LIBRARY_TOOL_METRIC_DIR N:\Siemens\NX\mach\resource\library\tool\metric\
    [4] UGII_CAM_LIBRARY_UDF_DIR         N:\Siemens\NX\mach\resource\library\udf\
    [4] UGII_CAM_MACHINING_KNOWLEDGE_DIR N:\Siemens\NX\mach\resource\machining_knowledge\
    [4] UGII_CAM_PART_DOC_CONFIG_FILE    N:\Siemens\NX\mach\resource\shop_doc\shop_doc.dat
    [4] UGII_CAM_POST_CONFIG_FILE        N:\Siemens\NX\mach\resource\postprocessor\template_post.dat
    [4] UGII_CAM_POST_DIR                N:\Siemens\NX\mach\resource\postprocessor\
    [4] UGII_CAM_RESOURCE_DIR            N:\Siemens\NX\mach\resource\
    [4] UGII_CAM_SAMPLES_DIR             N:\Siemens\NX\mach\samples\
    [4] UGII_CAM_SHOP_DOC_DIR            N:\Siemens\NX\mach\resource\shop_doc\
    [4] UGII_CAM_SPREADSHEET_DIR         N:\Siemens\NX\mach\resource\spreadsheet\
    [4] UGII_CAM_TAGGING_DIR             N:\Siemens\NX\mach\auxiliary\tagging\
    [4] UGII_CAM_TAGGING_DLL_DIR         N:\Siemens\NX\mach\auxiliary\tagging\application\
    [4] UGII_CAM_TAGGING_ENGLISH_DIR     N:\Siemens\NX\mach\auxiliary\tagging\english\
    [4] UGII_CAM_TAGGING_METRIC_DIR      N:\Siemens\NX\mach\auxiliary\tagging\metric\
    [4] UGII_CAM_TEMPLATE_IMAGE_DIR      N:\Siemens\NX\mach\resource\template_part\images\
    [4] UGII_CAM_TEMPLATE_PART_DIR       N:\Siemens\NX\mach\resource\template_part\
    [4] UGII_CAM_TEMPLATE_PART_ENGLISH_DIR N:\Siemens\NX\mach\resource\template_part\english\
    [4] UGII_CAM_TEMPLATE_PART_METRIC_DIR N:\Siemens\NX\mach\resource\template_part\metric\
    [4] UGII_CAM_TEMPLATE_SET_DIR        N:\Siemens\NX\mach\resource\template_set\
    [4] UGII_CAM_THREAD_MILL             N:\Siemens\NX\mach\auxiliary\thread_mill\thrm.dll
    [4] UGII_CAM_THREAD_MILL_DIR         N:\Siemens\NX\mach\auxiliary\thread_mill\
    [4] UGII_CAM_TOOL_PATH_DIR           N:\Siemens\NX\mach\resource\tool_path\
    [4] UGII_CAM_USER_DEF_EVENT_DIR      N:\Siemens\NX\mach\resource\user_def_event\
    [4] UGII_CAM_WIZARD_DIR              N:\Siemens\NX\mach\resource\wizard\
    [4] UGII_CAM_WORK_INSTRUCTION_DIR    N:\Siemens\NX\mach\resource\owi\
    [4] UGII_CANNED_MATERIAL_DIR         N:\Siemens\NX\ugphoto\ug_canned_mattex
    [4] UGII_CATIAV5_DIR                 N:\Siemens\NX\catiav5\
    [4] UGII_CATIA_DIR                   N:\Siemens\NX\ugcatia\
    [4] UGII_CGM2PDF                     N:\Siemens\NX\nxplot\bin\pdf
    [4] UGII_CGM_DEFAULTS                N:\Siemens\NX\ugii\cgmdef.txt
    [4] UGII_CHARACTER_FONT_DEFAULT      blockfont
    [4] UGII_CHARACTER_FONT_DIR          N:\Siemens\NX\ugii\ugfonts
    [4] UGII_CLASSPATH
   [34] UGII_CLASSPATH_PRELOAD           N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\axiom-api-1.2.10.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\axiom-impl-1.2.10.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\dom4j-1.6.1.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\GeolusNXIndexer8.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\isorelax.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\Jama-1.0.1.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\log4j-1.2.16.jar;N:\Siemens\NX\design_tools\shapesearch\GeolusNXIndexer\msv.jar
    [4] UGII_CONVERT_OLD_MOTION_CONTACTS 0
    [4] UGII_CREATE_OLD_MOTION_CONTACTS  0
    [4] UGII_CSHELP_API_DOCS             https://docs.plm.automation.siemens.com/tdoc/nx/1847/nx_api
    [4] UGII_CSHELP_DEFAULTS_DOCS        https://docs.plm.automation.siemens.com/data_services/resources/nx/1847/nx_help/common/en_US/graphics/fileLibrary/nx/cust_defaults
    [4] UGII_CSHELP_DOCS                 https://docs.plm.automation.siemens.com/tdoc/nx/1847/nx_help
    [4] UGII_CSHELP_FUSION_DOCS          https://docs.plm.automation.siemens.com/data_services/resources/nx/1847/nx_api/common/en_US/graphics/fileLibrary/nx/fusion
    [4] UGII_CUSTOM_DIRECTORY_FILE       N:\Siemens\NX\ugii\menus\custom_dirs.dat
    [4] UGII_DEFAULT_MENU_DIR            N:\Siemens\NX\ugii\menus
    [4] UGII_DOC_VERSION                 1847
    [4] UGII_DOTNET_USE_USER_DEFINED_KEYS 1
    [4] UGII_DRAFTING_STANDARD_DIR       N:\Siemens\NX\ugii\drafting_standards
    [4] UGII_DRAWING_COMPARE_OUTPUT_XML  0
    [4] UGII_DRILL_SIZE_HOLE_STANDARD_DIR N:\Siemens\NX\ugii\modeling_standards
    [4] UGII_DUMBIFY_FEATURE             1
    [4] UGII_EDITOR                      notepad
    [4] UGII_EMBEDDED_HELP               https://docs.plm.automation.siemens.com/docs/nx/1847/en_US
    [4] UGII_ENABLE_HOLE_SERIES          1
    [4] UGII_ENABLE_TS_UPDATE_FOR_SLIVER_REGIONS 0
    [4] UGII_ENGLISH_THREADS             N:\Siemens\NX\ugii\thd_english.dat
    [4] UGII_ENV_IMAGE_DIR               N:\Siemens\NX\ugphoto\env_images\
    [4] UGII_EPLIB_PART_LIB_VIEW_PATH    N:\Siemens\NX\routing\ugroute_mech\appview\;N:\Siemens\NX\routing\ugroute_elec\appview\
    [4] UGII_EPLIB_TABLE_PATH            N:\Siemens\NX\routing\ugroute_mech\metric\tables\;N:\Siemens\NX\routing\ugroute_elec\metric\tables\
    [4] UGII_FEAT_FAILURE_REPORT_TEMPLATE_FILE N:\Siemens\NX\ugii\xsl\FeatureFailureReportTemplate.xsl
    [4] UGII_FLEXIBLEPIPE_DIR            N:\Siemens\NX\simulation\flexiblepipe
    [4] UGII_FMBD_CGM_DIR                N:\Siemens\NX\routing\ugroute_elec\metric\parts
    [4] UGII_FMBD_DISABLE_ROTATION_VECTOR_ALIGNMENT FALSE
    [4] UGII_FMBD_FORMATS_FILE           N:\Siemens\NX\routing\ugroute_elec\rlist\fmbd_annotation.fmt
    [4] UGII_FMBD_PATTERN_DIR            N:\Siemens\NX\routing\ugroute_elec\metric\parts
    [4] UGII_FMBD_USE_LAYOUTS            FALSE
    [4] UGII_GDT_DIR                     N:\Siemens\NX\ugii\gdt_files
    [4] UGII_HDR_IMAGE_DIR               N:\Siemens\NX\ugphoto\hdr_images
    [4] UGII_HELP_RELEASE_NOTES          https://docs.plm.automation.siemens.com/tdoc/nx/1847/release_notes/#uid:index
    [4] UGII_HELP_WHATS_NEW              https://docs.plm.automation.siemens.com/tdoc/nx/1847/nx_help/#uid:index_whatsnew
    [3] UGII_HTML_UGDOC                  https://docs.plm.automation.siemens.com/tdoc/nx/1847/nx_help/#uid:index
    [4] UGII_INOP_SE_IMPORT_ONLY_DESIGN_PART 0
    [4] UGII_INSPECTION_BASE_DIR         N:\Siemens\NX\cmm_inspection\
    [4] UGII_INSPECTION_CONFIG           N:\Siemens\NX\cmm_inspection\resource\configuration\inspection_general.dat
    [4] UGII_INSPECTION_CONFIG_DIR       N:\Siemens\NX\cmm_inspection\resource\configuration\
    [4] UGII_INSPECTION_LIBRARY_DEVICE_ASCII_DIR N:\Siemens\NX\cmm_inspection\resource\library\device\ascii\
    [4] UGII_INSPECTION_LIBRARY_DEVICE_DATA_DIR N:\Siemens\NX\cmm_inspection\resource\library\device\ascii\
    [4] UGII_INSPECTION_LIBRARY_DEVICE_DIR N:\Siemens\NX\cmm_inspection\resource\library\device\
    [4] UGII_INSPECTION_LIBRARY_DEVICE_GRAPHICS_PATH N:\Siemens\NX\cmm_inspection\resource\library\device\graphics\
    [4] UGII_INSPECTION_LIBRARY_DEVICE_INCLASS_DIR N:\Siemens\NX\cmm_inspection\resource\library\device\inclass\
    [4] UGII_INSPECTION_LIBRARY_DIR      N:\Siemens\NX\cmm_inspection\resource\library\
    [4] UGII_INSPECTION_LIBRARY_INSTALLED_MACHINES_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\installed_machines\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_ASCII_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\ascii\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_DATA_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\ascii\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_GENIUS_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\genius\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_GRAPHICS_PATH N:\Siemens\NX\cmm_inspection\resource\library\machine\graphics\
    [4] UGII_INSPECTION_LIBRARY_MACHINE_INCLASS_DIR N:\Siemens\NX\cmm_inspection\resource\library\machine\inclass\
    [4] UGII_INSPECTION_LIBRARY_TOOL_ASCII_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\ascii\
    [4] UGII_INSPECTION_LIBRARY_TOOL_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\
    [4] UGII_INSPECTION_LIBRARY_TOOL_ENGLISH_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\english\
    [4] UGII_INSPECTION_LIBRARY_TOOL_GENIUS_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\genius\
    [4] UGII_INSPECTION_LIBRARY_TOOL_GRAPHICS_PATH N:\Siemens\NX\cmm_inspection\resource\library\tool\graphics\
    [4] UGII_INSPECTION_LIBRARY_TOOL_INCLASS_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\inclass\
    [4] UGII_INSPECTION_LIBRARY_TOOL_METRIC_DIR N:\Siemens\NX\cmm_inspection\resource\library\tool\metric\
    [4] UGII_INSPECTION_POST_DIR         N:\Siemens\NX\cmm_inspection\resource\postprocessor\
    [4] UGII_INSPECTION_RESOURCE_DIR     N:\Siemens\NX\cmm_inspection\resource\
    [4] UGII_INSPECTION_TEMPLATE_PART_DIR N:\Siemens\NX\cmm_inspection\resource\template_part\
    [4] UGII_INSPECTION_TEMPLATE_PART_ENGLISH_DIR N:\Siemens\NX\cmm_inspection\resource\template_part\english\
    [4] UGII_INSPECTION_TEMPLATE_PART_METRIC_DIR N:\Siemens\NX\cmm_inspection\resource\template_part\metric\
    [4] UGII_INSPECTION_TEMPLATE_SET_DIR N:\Siemens\NX\cmm_inspection\resource\template_set\
    [4] UGII_INSPECTION_USER_DEF_EVENT_DIR N:\Siemens\NX\cmm_inspection\resource\user_def_event\
    [4] UGII_IRAYPLUS_CANNED_MATERIAL_DIR N:\Siemens\NX\ugphoto\IrayPlus_ug_canned_mattex
    [4] UGII_ISO_VOC                     N:\Siemens\NX\mach\auxiliary\iso.voc
    [5] UGII_JAVA_HOME                   C:\Program Files\Java\jre1.8.0_211
    [4] UGII_JVM_LIBRARY_DIR             C:\Program Files\Java\jre1.8.0_211\bin\server
    [4] UGII_JVM_OPTIONS
    [4] UGII_KF_CLASS_DIR                N:\Siemens\NX\ugii\dfa
    [4] UGII_LANG                        english
    [4] UGII_LEARNING_CFM_URL            https://www.siemens.com/plm/LearningAdvantage
    [4] UGII_LEGACY_TOL_FEAT_SETTINGS    0
    [4] UGII_LIB1                        C:\Users\pass321\AppData\Local\Temp
    [4] UGII_LIB2                        N:\Siemens\NX\ugii\
    [4] UGII_LI_CLBIN_DIR                C:\Users\pass321\AppData\Local\Temp
    [4] UGII_LI_LAYLA_DIR                N:\Siemens\NX\ugphoto
    [4] UGII_LI_TOP                      N:\Siemens\NX\ugphoto\ray_traced_studio
    [4] UGII_LOAD_OPTIONS
    [4] UGII_LOCALIZATION_FILES          N:\Siemens\NX\localization\translations
    [4] UGII_LOCAL_USER_DEFAULTS         C:\Users\pass321\AppData\Local\Siemens\NX1847\NX_user.dpv
    [4] UGII_LOCAL_USER_DRAFTING_STANDARD_DIR C:\Users\pass321\AppData\Local\Siemens\NX1847
    [4] UGII_LOCAL_USER_SHIP_NAVIGATOR_DIR C:\Users\pass321\AppData\Local\Siemens\NX1847
    [4] UGII_LOCAL_USER_TOGGLE_DEFAULTS  C:\Users\pass321\AppData\Local\Siemens\NX1847\feature_toggle_user.fcg
    [4] UGII_LWIRAY_CONTENT_ROOTDIR      N:\Siemens\NX\ugphoto\Iray+\content\evaluation
    [4] UGII_LWIRAY_ROOTDIR              N:\Siemens\NX\ugphoto\Iray+\content\core
    [4] UGII_MAX_FACETING_SCALE          125.0
    [4] UGII_MDP_AUTOMATION_EXCEPTION_FILE N:\Siemens\NX\ugii\custom_mdp_exceptions.dat
    [4] UGII_METRIC_THREADS              N:\Siemens\NX\ugii\thd_metric.dat
    [4] UGII_MONITOR_DIR                 N:\Siemens\NX\nxcae_extras\tmg\exe
    [4] UGII_MSC_NASTRAN                 C:\Program Files\msc\bin\nastran.exe
    [4] UGII_MSC_NASTRAN_VERSION         2005
    [4] UGII_MXUG_FILE                   C:\Users\pass321\AppData\Local\Temp\
    [4] UGII_NO_TIFF_SEARCH
    [4] UGII_NXACIS_DIR                  N:\Siemens\NX\translators\nxacis\
   [26] UGII_NXMLP_GRID_DISTANCE         5000
   [26] UGII_NXMLP_RELATION_BROWSER      0
    [4] UGII_NXPROE_DIR                  N:\Siemens\NX\nxproe\
    [4] UGII_NX_NASTRAN                  N:\Siemens\NX\nxnastran\bin\nastran.exe
    [4] UGII_NX_NASTRAN_VERSION          2019.1
    [4] UGII_OLD_SKETCH                  0
    [4] UGII_ONESTEP_ANALYSIS_TEMPLATE_FILE N:\Siemens\NX\ugii\xsl\OnestepAnalysisTemplate.xsl
    [1] UGII_PACKAGE                     ugii
    [4] UGII_PACKAGE_DIR                 N:\Siemens\NX\ugii
    [4] UGII_PHYS_MATERIAL_LIB_DATA_DIR  N:\Siemens\NX\ugii\materials\
    [4] UGII_PHYS_MATERIAL_LIB_DIR       N:\Siemens\NX\ugii\materials\english\
    [4] UGII_PHYS_MATERIAL_LIB_PATH      .\;N:\Siemens\NX\ugii\materials\
    [4] UGII_PLATFORM                    x64wnt
    [4] UGII_PMI_DIR                     N:\Siemens\NX\ugii\pmi
    [4] UGII_PMI_SYMBOL_LIBRARY_DIR      N:\Siemens\NX\ugii\symbol\PMI_Symbols
    [4] UGII_PRESOLVER                   N:\Siemens\NX\simulation\PreSolver\bin\ScPreSolver.exe
    [4] UGII_PRINTER
    [4] UGII_PYTHONPATH                  N:\Siemens\NX\nxbin\python;N:\Siemens\NX\nxbin\python\Python37.zip
    [4] UGII_PYTHON_DLL                  python37.dll
    [4] UGII_PYTHON_HOME                 N:\Siemens\NX\nxbin\python
    [4] UGII_PYTHON_LIBRARY_DIR          N:\Siemens\NX\nxbin\python
    [4] UGII_QS_DEFS_DIR                 N:\Siemens\NX\tolstackup\ugquickstack\application
    [4] UGII_REFL_IMAGE_DIR              N:\Siemens\NX\ugii\ugvisuals\
    [4] UGII_RENDER_ARTISTIC_DIR         N:\Siemens\NX\ugphoto\artistic_render\
    [4] UGII_RLIST_PATH                  N:\Siemens\NX\routing\ugroute_elec\rlist\
    [4] UGII_RLIST_SCHEMA_FILE           N:\Siemens\NX\routing\ugroute_elec\rlist\routelist.xsd
    [4] UGII_ROUTE_CONVERT_SLACK_TO_LOCK_LENGTH TRUE
    [4] UGII_ROUTE_ELEC_APP_VIEW         N:\Siemens\NX\routing\ugroute_elec\appview\ugroute_elec_metric.xml
    [4] UGII_ROUTE_ELEC_KIT_DIR          N:\Siemens\NX\routing\ugroute_elec
    [4] UGII_ROUTE_ELEC_PART_PATH        N:\Siemens\NX\routing\ugroute_elec\metric\parts
    [4] UGII_ROUTE_LGCL_APP_VIEW         N:\Siemens\NX\routing\ugroute_mech\appview\ugroute_lgcl_metric.xml
    [4] UGII_ROUTE_LGCL_KIT_DIR          N:\Siemens\NX\routing\ugroute_mech
    [4] UGII_ROUTE_LGCL_PART_PATH        N:\Siemens\NX\routing\ugroute_mech\metric\parts
    [4] UGII_ROUTE_MECH_APP_VIEW         N:\Siemens\NX\routing\ugroute_mech\appview\ugroute_mech_metric.xml
    [4] UGII_ROUTE_MECH_KIT_DIR          N:\Siemens\NX\routing\ugroute_mech
    [4] UGII_ROUTE_MECH_PART_PATH        N:\Siemens\NX\routing\ugroute_mech\metric\parts
    [4] UGII_ROUTE_SKIP_ENGAGE_CHARX     TRUE
    [4] UGII_ROUTE_SKIP_LENGTH_ADDITION_CHARX TRUE
    [4] UGII_ROUTE_SKIP_ROUTING_LEVEL_CHECKING TRUE
    [4] UGII_ROUTE_UGMANAGER_MODE        FALSE
    [4] UGII_ROUTING_APP_VIEW_DIR        N:\Siemens\NX\routing\ugroute_mech\appview\;N:\Siemens\NX\routing\ugroute_elec\appview\
    [4] UGII_ROUTING_BEND_TABLES_PATH    N:\Siemens\NX\routing\ugroute_mech\metric\tables\
    [4] UGII_ROUTING_BOM_PATH            N:\Siemens\NX\routing\ugroute_mech\metric\parts\
    [4] UGII_ROUTING_KIT_UNITS           metric
    [4] UGII_SAMCEF                      N:\Siemens\NX\simulation\samcef\Exec\
    [4] UGII_SCHEMA                      N:\Siemens\NX\ugii\ugschema
    [4] UGII_SCREW_CLEARANCE_HOLE_STANDARD_DIR N:\Siemens\NX\ugii\modeling_standards
    [4] UGII_SDI_ALLOW_LARGE_TIF         1
    [4] UGII_SDI_BASE                    N:\Siemens\NX\nxplot
    [4] UGII_SDI_EXPORT_NEW              1
    [4] UGII_SDI_OUTPUT_DIR              C:\Users\pass321\AppData\Local\Temp
    [4] UGII_SDI_PS_PAGE_SIZE            1
    [4] UGII_SHARE                       N:\Siemens\NX\nxbin
    [4] UGII_SHIP_DRAFTING_ANNOTATION_MAPPING N:\Siemens\NX\nxship\shipdrafting\XML\ship_annotation_mapping_file.xml
    [4] UGII_SHIP_DRAFTING_ANNOTATION_SYMBOLS N:\Siemens\NX\nxship\shipdrafting\symbol\ug_drafting_shipbuilding_default_symbols.sbf
    [4] UGII_SHIP_DRAFTING_AREACENTERLINES_MAPPING N:\Siemens\NX\nxship\shipdrafting\XML\ship_area_centerline_mapping_file.xml
    [4] UGII_SHIP_DRAFTING_CONFIG_DIR    N:\Siemens\NX\nxship\shipdrafting\application
    [4] UGII_SHIP_DRAFTING_DIR           N:\Siemens\NX\nxship\shipdrafting
    [4] UGII_SHIP_DRAFTING_DRAFTINGLINES_MAPPING N:\Siemens\NX\nxship\shipdrafting\XML\ship_drafting_line_mapping_file.xml
    [4] UGII_SHIP_DRAFTING_SYMBOLS_MAPPING N:\Siemens\NX\nxship\shipdrafting\XML\ship_symbols_mapping_file.xml
    [4] UGII_SHOPS_DIE_MOLD_CONFIG       N:\Siemens\NX\mach\resource\configuration\shops_diemold.dat
    [4] UGII_SHOPS_MACHINERY_CONFIG      N:\Siemens\NX\mach\resource\configuration\shops_machinery.dat
    [4] UGII_SHOWROOM_DATA_DIR           N:\Siemens\NX\ugphoto\ug_environment
    [4] UGII_SPREADSHEET                 N:\Siemens\NX\nxbin\
    [4] UGII_STEREO                      1
    [4] UGII_STEREO_ADJUST_PERSPECTIVE_AUTOMATICALLY 1
    [4] UGII_STEREO_DISABLES_UI_TRANSPARENCY 1
    [4] UGII_SUPPORT_HOMOGENIZATION_DIR  N:\Siemens\NX\simulation\support_homogenization
    [4] UGII_SURFACE_FINISH              OFF
    [4] UGII_SW_LIBRARY                  CrossCadWareX64.dll
    [4] UGII_SW_SCHEMA                   N:\Siemens\NX\ugii
    [4] UGII_SYSNOISE                    N:\Siemens\NX\simulation\acoustics\sysnoise\bin\sysnoise_nogui.bat
    [4] UGII_SYSTEM_SCENE_DATA_DIR       N:\Siemens\NX\ugphoto\system_scene_data_dir
    [4] UGII_TABLE_TEMPLATES             N:\Siemens\NX\ugii\table_files\
    [4] UGII_TAB_LABEL_FORMATS_FILE      N:\Siemens\NX\ugii\tab_label_format_file.xml
    [4] UGII_TAPEBAUD                    1200
    [4] UGII_TC_SOA_VERSION              TC11000.2.0
    [4] UGII_TEXTURE_TIFF_IMAGE_DIR      N:\Siemens\NX\ugstudio\
    [4] UGII_THREADED_HOLE_STANDARD_DIR  N:\Siemens\NX\ugii\modeling_standards
    [4] UGII_TMG_DIR                     N:\Siemens\NX\nxcae_extras\tmg
    [4] UGII_TMP_DIR                     C:\Users\pass321\AppData\Local\Temp
    [4] UGII_TRUESHADING_DIR             N:\Siemens\NX\ugii\true_shading
    [4] UGII_TSV_DEFS_DIR                N:\Siemens\NX\tolstackup\application
    [4] UGII_UDF_LAYER_ORIGINAL          0
    [4] UGII_UGDOC_API_BASE              https://docs.plm.automation.siemens.com
    [4] UGII_UGDOC_BASE                  https://docs.plm.automation.siemens.com
    [4] UGII_UGDOC_LANG                  en_US
    [4] UGII_UGMANAGER_DIR               N:\Siemens\NX\nxbin\
    [4] UGII_UGMX                        N:\Siemens\NX\ugmx\me\etc\startmcad
    [4] UGII_UGMX_FILE                   C:\Users\pass321\AppData\Local\Temp\
    [4] UGII_UGSMD_STDS_LIBRARY          N:\Siemens\NX\ugii\
    [4] UGII_UG_CUSTOM_DIRECTORY_FILE    N:\Siemens\NX\ugii\menus\ug_custom_dirs.dat
    [4] UGII_UG_LIBRARY_DIR              N:\Siemens\NX\mach\resource\ug_library\
    [4] UGII_UG_LIBRARY_GENIUS_TCP_HOST  localhost
    [4] UGII_UG_LIBRARY_GENIUS_TCP_PORT  2326
    [4] UGII_UNIMAJ_VOC                  N:\Siemens\NX\mach\auxiliary\unimaj.voc
    [4] UGII_UNIMIN_VOC                  N:\Siemens\NX\mach\auxiliary\unimin.voc
    [4] UGII_UPDATE_ALL_ID_SYMBOLS_WITH_PLIST 1
    [4] UGII_USERFCN                     N:\Siemens\NX\ugopen
    [4] UGII_USER_SHOWROOM_DATA_DIR
    [4] UGII_UTIL                        N:\Siemens\NX\ugii\
    [4] UGII_VD_APO_REQ_SPREADSHEET_FILE N:\Siemens\NX\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_spreadsheet.xls
    [4] UGII_VD_APO_REQ_XML_FILE         N:\Siemens\NX\ugautomotive\packaging\requirements\a_pillar_obstruction_requirement_text.xml
    [4] UGII_VD_DFV_REQ_SPREADSHEET_FILE N:\Siemens\NX\ugautomotive\packaging\requirements\direct_field_view_requirement_spreadsheet.xls
    [4] UGII_VD_DFV_REQ_XML_FILE         N:\Siemens\NX\ugautomotive\packaging\requirements\direct_field_view_requirement_text.xml
    [4] UGII_VD_DP_REQ_SPREADSHEET_FILE  N:\Siemens\NX\ugautomotive\packaging\requirements\driver_posture_requirement_spreadsheet.xls
    [4] UGII_VD_DP_REQ_XML_FILE          N:\Siemens\NX\ugautomotive\packaging\requirements\driver_posture_requirement_text.xml
    [4] UGII_VD_JOINT_REQ_SPREADSHEET_FILE N:\Siemens\NX\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_spreadsheet.xls
    [4] UGII_VD_JOINT_REQ_XML_FILE       N:\Siemens\NX\ugautomotive\packaging\requirements\manikin_joint_angle_requirement_text.xml
    [4] UGII_VD_MC_REQ_SPREADSHEET_FILE  N:\Siemens\NX\ugautomotive\packaging\requirements\mirror_certification_requirement_spreadsheet.xls
    [4] UGII_VD_MC_REQ_XML_FILE          N:\Siemens\NX\ugautomotive\packaging\requirements\mirror_certification_requirement_text.xml
    [4] UGII_VD_WS_REQ_SPREADSHEET_FILE  N:\Siemens\NX\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_spreadsheet.xls
    [4] UGII_VD_WS_REQ_XML_FILE          N:\Siemens\NX\ugautomotive\packaging\requirements\windshield_vision_zones_requirement_text.xml
    [4] UGII_VERICUT                     N:\Siemens\NX\win_nt\commands\vericut.bat
    [4] UGII_VL2SC_DIR                   N:\Siemens\NX\mech\vl2sc_toolkit\
    [4] UGII_VSAEXPORT_DIR               N:\Siemens\NX\ugvsaexport
    [4] UGII_WAVE_DELETE                 0
    [4] UGII_WELD_BASE_DIR               N:\Siemens\NX\ugweld
   [32] UGPHOTO_APP_DIR                  N:\Siemens\NX\ugphoto
    [4] UGTO2D_DIR                       N:\Siemens\NX\ugto2d\
    [4] UGWELD_DIR                       N:\Siemens\NX\ugweld
   [16] UG_APP_ADDITIVE_USE_MESH_3MF     0
    [4] UG_IMAGE                         ugspawn.bat
    [4] UG_VPACK_DIR                     N:\Siemens\NX\ugautomotive\packaging
    [4] UNC_CAM_DIR                      N:\Siemens\NX\sheetmfg\unc\
    [4] UNC_LANG                         eng
    [1] USERDOMAIN                       WIN-20D2V681BGN
    [1] USERNAME                         pass321
    [1] USERPROFILE                      C:\Users\pass321
    [4] USER_GEO_UNF                     *N:\Siemens\NX\unfold\flatpat.grx
    [4] USER_ICADIF                      N:\Siemens\NX\icadif\uficad
    [4] USER_PDAIF                       N:\Siemens\NX\ugpatif\ugpatif
    [4] USER_PUNCH                       *N:\Siemens\NX\punchpress\punchlaser.grx
    [4] USER_PUNCHGRID                   *N:\Siemens\NX\punchpress\punchgrid.grx
    [4] USER_PUNCHTOOLS                  *N:\Siemens\NX\punchpress\buildtool.grx
   [13] WELD_APP_DIR                     N:\Siemens\NX\ugweld
Variable locations:
    [1] System Environment
    [2] N:\Siemens\NX\design_tools\checkmate\customization\ugcheckmate.dat
    [3] Set internally
    [4] N:\Siemens\NX\ugii\ugii_env_ug.dat
    [5] Registry
    [6] N:\Siemens\NX\SIMULATION\manifest\cae_env.dat
    [7] N:\Siemens\NX\CMM_INSPECTION\manifest\cmm_inspection_env.dat
    [8] N:\Siemens\NX\NXHUMAN\manifest\hm_env.dat
    [9] N:\Siemens\NX\UGII\manifest\dmu\dmu_env.dat
    [10] N:\Siemens\NX\NXSHIP\manifest\nxship_env.dat
    [11] N:\Siemens\NX\UGII\manifest\polygon_modeling\polygon_modeling_env.dat
    [12] N:\Siemens\NX\UGII\manifest\nx_realize_shape\nx_realize_shape_env.dat
    [13] N:\Siemens\NX\UGWELD\manifest\weld_env.dat
    [14] N:\Siemens\NX\DRAFTING\manifest\drafting_env.dat
    [15] N:\Siemens\NX\DIAGRAMMING\manifest\PID_env.dat
    [16] N:\Siemens\NX\MACH\manifest\additive_manufacturing_env.dat
    [17] N:\Siemens\NX\MECHATRONICS\manifest\mechatronics_env.dat
    [18] N:\Siemens\NX\SIMULATION\manifest\aerostructures\aerostructures_env.dat
    [19] N:\Siemens\NX\TDP\manifest\TDP_env.dat
    [20] N:\Siemens\NX\AUTOMATION_DESIGNER\manifest\AutomationDesigner_env.dat
    [21] N:\Siemens\NX\UGFPCD\manifest\fpcd_env.dat
    [22] N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\PressLineSimul_env.dat
    [23] N:\Siemens\NX\UGII\manifest\texture_modeling\texture_modeling_env.dat
    [24] N:\Siemens\NX\MPA\manifest\mpa_env.dat
    [25] N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\LineDesigner_env.dat
    [26] N:\Siemens\NX\MACH\manifest\mlp_env.dat
    [27] N:\Siemens\NX\ROUTING\manifest\rout_env.dat
    [28] N:\Siemens\NX\UGPCBXCHANGE\manifest\pcb_env.dat
    [29] N:\Siemens\NX\MECHATRONICS\manifest\animation_designer_env.dat
    [30] N:\Siemens\NX\MANUFACTURING_PLANNING\manifest\ToolDesigner_env.dat
    [31] N:\Siemens\NX\MACH\manifest\cam_env.dat
    [32] N:\Siemens\NX\UGPHOTO\manifest\ugphoto_env.dat
    [33] N:\Siemens\NX\MECHATRONICS\manifest\Mechatronics_player_env.dat
    [34] N:\Siemens\NX\DESIGN_TOOLS\manifest\design_tools_env.dat
    [35] N:\Siemens\NX\STAMPING_TOOLS\manifest\stampingtools_env.dat
    [36] N:\Siemens\NX\MOLDWIZARD\manifest\moldwizard_env.dat
    [37] N:\Siemens\NX\UGAUTOMOTIVE\manifest\automotive_env.dat
    [38] N:\Siemens\NX\DRAFTING\manifest\MFGViewMaker_env.dat
Re: CSE - to_ini
Hello
I saw on one of your snapshots that you selected "External NC Code file simulation". Please be aware that the post run created the to_ini.ini file including the tool data. If you simulate external NC code these file will not be created.
Try to select some operations and post them, that should create the to_ini.ini file.
Thomas Schulz
Siemens PLM
