Re: CSE - to_ini
Thanks, didnt knew that, i il try this way.
Re: CSE - to_ini
Hello.Thanks. Worked but not completely.
To_ini have been generated in part folder, simulation "eats" it when i copied it from part folder into "\sim03_mill_4ax\cse_driver\sinumerik\subprog" folder. After that no errors about tool name, but wrong g54 position.
Looks like post use machine zero instead of g54.
Spoiler
$P_UIFR[0]=CTRANS(X,0.0,Y,0.0,Z,0.0)
$TC_TP1[1]=1
$TC_TP2[1]="FREZAD50"
$TC_TP8[1]=10
$TC_DP1[1,1]=120
$TC_DP2[1,1]=8.0000
$TC_DP3[1,1]=100.0000
$TC_DP4[1,1]=0.0000
$TC_DP5[1,1]=0.0000
$TC_DP6[1,1]=25.0000
$TC_DP7[1,1]=0.0000
$TC_MPP6[1,1]=1
$TC_TP1[2]=2
$TC_TP2[2]="FREZAD80"
$TC_TP8[2]=10
$TC_DP1[2,2]=120
$TC_DP2[2,2]=6.0000
$TC_DP3[2,2]=100.0000
$TC_DP4[2,2]=0.0000
$TC_DP5[2,2]=0.0000
$TC_DP6[2,2]=40.0000
$TC_DP7[2,2]=0.0000
$TC_MPP6[1,1]=2
$TC_TP1[3]=3
$TC_TP2[3]="FREZAD25"
$TC_TP8[3]=10
$TC_DP1[3,3]=120
$TC_DP2[3,3]=50.0000
$TC_DP3[3,3]=75.0000
$TC_DP4[3,3]=0.0000
$TC_DP5[3,3]=0.0000
$TC_DP6[3,3]=12.5000
$TC_DP7[3,3]=0.0000
$TC_MPP6[1,3]=3
$TC_TP1[4]=4
$TC_TP2[4]="FREZAD34.7"
$TC_TP8[4]=10
$TC_DP1[4,4]=120
$TC_DP2[4,4]=3.0000
$TC_DP3[4,4]=100.0000
$TC_DP4[4,4]=0.0000
$TC_DP5[4,4]=0.0000
$TC_DP6[4,4]=17.3500
$TC_DP7[4,4]=0.0000
$TC_MPP6[1,1]=4
$TC_TP1[5]=5
$TC_TP2[5]="SVERLOD16"
$TC_TP8[5]=10
$TC_DP1[5,5]=200
$TC_DP2[5,5]=0.0000
$TC_DP3[5,5]=200.0000
$TC_DP4[5,5]=0.0000
$TC_DP5[5,5]=0.0000
$TC_DP6[5,5]=8.0000
$TC_DP7[5,5]=8.0000
$TC_MPP6[1,5]=5
$TC_TP1[6]=6
$TC_TP2[6]="FREZAD16"
$TC_TP8[6]=10
$TC_DP1[6,6]=120
$TC_DP2[6,6]=50.0000
$TC_DP3[6,6]=75.0000
$TC_DP4[6,6]=0.0000
$TC_DP5[6,6]=0.0000
$TC_DP6[6,6]=8.0000
$TC_DP7[6,6]=0.0000
$TC_MPP6[1,6]=6
M17
Spoiler
Spoiler
this is sim03_mill_4ax-Main.ini file located "N:\Siemens\NX\MACH\resource\library\machine\installed_machines\sim03_mill_4ax\cse_driver\sinumerik\"
PMAC PGUD CHAN_DATA G40 D0 TO_INI M17
Re: CSE - to_ini
The offset is defined by the MCS object defined as local and fixture offset number 1 -> G54 2-> G55
and will end as this in the ini file
; For G54
$P_UIFR[1]=CTRANS(X,0.0,Y,0.0,Z,0.0)
; for G55
$P_UIFR[2]=CTRANS(X,0.0,Y,0.0,Z,0.0)
Thomas Schulz
Siemens PLM
