Re: CSE, tools for turret
To be continued..
Next problem. I cannot to rotate turning tools in turret pockets, I need to rotate 90 deg - I try to rotate pocket CSYS - no results. The same problem if I use toolholder - I rotate tool mount CSYS in tool holder, but tool not rotated.
Either again redefine the tool mount junctions. The X/Y plane of that junction will define the turning working plane.
If you need tool the one or the other way it is how you define them in the tool dialog. Make clear you define that correctly in the original mounting position.
Thomas Schulz
Siemens PLM
Hello, Thomas!
Thank you for reply!
A problem was - tool orientation ("Operation", "MCS_/.."). I add turning MCS, set tool orientation to MCS - and all tools aligned to upright position.
