CSE turning 3d material removal
Sorry.. I remember, for old version NX was impossible 3d material removing for turning (NC Code File Simulation).
I try to simulate simple lathe operations - and no material removing. NX8.5.3.3
Impossible for this version NX?
3 REPLIES 3
Re: CSE turning 3d material removal
Hello
3D-Material Removal is possible in NX 8.5.3 turning.
There are some lacks when turning and milling are mixed.
One note. I know, it possible for toolpath simulation.
But I need NC code file simulation...
Hello Yuri,
I built a Integrex simkit on NX 8.5.3.3 and the NC code simulation worked with material removal.
Like @schauerm3 mentioned, have some lack about simulation with milling and turning operations, but worked.
I hope this helps.
Thanks.
Jean Marcel
Application Engineer
Ally PLM Solutions | PROLIM PLM
