CSYS Dispaly
Ever since upgrading to NX12.0.2 MP3...
Everytime I create a new file or open a file I get CSYS's displayed and I have to hide them off
Been looking for a new customer default or something, not seeing any. Any csys displayed.pngIdeas??
{Paul Schneider}, {CNC Programmer}, {DRT-Rochester}
Production: {NX11.0.2,MP5, NX12.0.2, MP4}
12 REPLIES 12
Re: CSYS Dispaly
You mean about displayed WSC or few datum planes and CSYS (layer 61)?
In second case - when you create new model - use Blank template, without any CSYS. Or - edit your template.
Re: CSYS Dispaly
No I'm talking about the little ghost XYZ CSYS at the tops of the holes and on the part coordinate system.
Very weird. I hi-light them all and hide, but don't know why they are showing up
Re: CSYS Dispaly
Have you applied any Feature Based machining to the part?
Is this showing up in modeling or just manufacturing?
Re: CSYS Dispaly
No I have not. Ones over the holes seem to be from helicoils in the assembly.
I have hidden them by expression, so nothing from them should be coming thru
Re: CSYS Dispaly
Are they under the non timestamp geometry?
Glenn Balon
Production: NX 12.0.2 MP10 Primarily CAM
Re: CSYS Dispaly
I'm seeing a couple there...
Re: CSYS Dispaly
See if you can delete or place on a different layer.
Also check "Reference Set" of your machine sim components. Try using "Model."
Save before trying all this. I am just throwing things out there I would try.
Glenn Balon
Re: CSYS Dispaly
These seem to be the CSYSs of the machine kinematic junctions.
You should put them on a different layer when you create the junctions or you can select "hide junctions" in the machine tool builder navigator.
Re: CSYS Dispaly
I've done hide junctions in MTB, but these don't seem to follow the rule and keep reappearing
Maybe because they are in that non-time stamp geometry group
In my earlier example I seem to see them for cordinate system origins on parts, in an assembly.
Not sure why. this just started in 12.0.2
