Cam Express 5-Axis Machining
Hi Cam masters,
I am new with NX Cam, can you guys teach me how to machine the attached photo of an object by a 5-axis machine using nx cam express without using the surface area as drive method. Client wants to know a faster and easier way to machine similar objects as show. Client does not want to make a half sphere just to make it as a drive method.
Also attached is the solid edge file of the part
All replies will be much appreciated.
Thank you,
Re: Cam Express 5-Axis Machining
You need a Discussion Forum of Magic Sticks resellers..
Or you need developer who will able to build custom strategy for NX CAM.
Hi @ReyL,
did you download NX12.0.1 and used Multi Axis Guiding Curves as I suggested in this topic 5-axis-Machining ?
This would be my preferred way to program such parts.
Cheers,
Alexander
Lead Product Manager - Mold & Die
