Re: Can not start NX12.0.2 post builder.
I can not find any clue from the message.
I did
- remove 12.0.2
- reinstall 12.0.2  ==> start postbuilder  ==> fail
- then install MP2 ==> start postbuilder ==> still fail
Siemens Legend Siemens Legend
Siemens Legend
The batch script run doesn't show any undefined variables. You would have to see if the syslog says anything?
Dose the syslog name like sam230cbe50.syslog?
I could not catch it. It was deleted when postbuilder exited.
Siemens Legend
Is your POSTBUILD installed formally along with the rest of the NX?
The syslog should be in UGII_TMP_DIR, normally C:\temp. Or you can find that out when you display the syslog from a NX session. The first 2 lines should say something like:
*** C:\temp\XXX6280338b.syslog
*** system log created by ling on Mon Oct 15 16:52:15 2018 Pacific Daylight Time
which indicates the location of the file. "XXX" will be your login ID.
You can have the folder open before you start PB; then, you will see a new syslog getting created.  I'm not sure how or why your syslog gets deleted automatically.
