Centrifugal Compressor Impeller machining technology
Hi!
I have NX11 Learning Edition and I can't use operations from mill_multi_blade group like hub finish etc.
Is there any way to do this with other operations ? I need to know how to rough this, finish blade and splitters and finish hub. As an example of part lets focus on the impeller from manufacturing tutorial.
Thank you in advance!
Marek
Re: Centrifugal Compressor Impeller machining technology
Siemens Legend Siemens Legend
Siemens Legend
Hi Merek,
You can use general purpose operations, create a lot of asisting geometries try and error and get some result. since this process is so tedious we invested into a special suite of operations intended to focus this set of part famoilies. I would invest in getting a proper license rathe than going this route.
Yours,
Eddy Finaro
NX CAM Product Manager
Siemens PLM
