Chamfering not possible
Builder
Builder
 I would like to chamfer this Feature with cavity mill but I get an error.
I dont know how to solve this. I tried with chamfer milling but it does not recognizes the chamfer.
Hope you can help - Thank you
NX 11.0.1.11
Re: Chamfering not possible
Don't use Cavity mill for this.
Planar mill is the answer.
-Select boundary > top face > tool outside
-Select floor (same top face)
-Method = Profile
-Cutting > Stock > Final floor stock = -1.5
-Generate
Patrick Delisse
KMWE - DutchAero
NX11.0, CAMPOST V22, Vericut 8.1
Builder
Builder
Thank you for your solution.
Actually I forgot to mention, that I want to teach that operation to MKE - so boundaries
are bad because they are not compatible. Is there a way to do that?
Thank you Smiley Happy
NX 11.0.1.11
Another option is to use FloorWall
Now you have to play with floor and wall stock to position the tool correctly
Patrick Delisse
KMWE - DutchAero
planar mill - better is set floor just bellow the chamfer , tool tip will not collide with wall.
floor wall - set chamfer as a wall, exact positioning, set z-depth offset to get floor preview jsut bellow the chamfer (again, tool shouldnt collide with the wall)
no negative stocks
Siemens Legend Siemens Legend
Siemens Legend
See attached. Planar Profile is best. You simply pick the curve and set the Drive Point to SYS_OD_CHAMFER. No floor definition necessary.
Builder
Builder
Thank you this is very good for me Smiley Happy
NX 11.0.1.11
