Change Manufacturing to Drafting, then wcs set to csys
WCS set in any place of model, body and etc. when i switch application from manufacturing to drafting (first time in part) wcs moved to csys. how disable this?
Re: Change Manufacturing to Drafting, then wcs set to csys
Hi @Kingston,
would you mind sharing the part and/ or a video of your issue described here?
Thanks in advance,
Cheers,
Alexander
I can not do it.
The move wcs is associated with the custom template in the TC, and when reconfigure template, this error not present
