Changing Units on NX 9
After conversion process from inch to mm through comand prompt i and getiing message that 3 files are failed on a complete assembly.
how can i find the root cause of that
Conversion SUCCESS
Saving: D:\Users\nikhil.das\Desktop\01\C001_1633_a_assy.R00_001.prt
255 files successfully converted
0 files generated warnings
3 files failed to convert
Re: Changing Units on NX 9
The only time I have seen this is when some of the components are already in the units your trying to convert to.
Look at the individual components and check
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
I have also seen errors when the file is from a newer version than the program you are converting with. I believe it showed a message stating this though. The conversion program is tied to the NX version. For example, running conversion with NX10 on files from NX8 and you will have a bunch of NX new NX10 files. Try in reverse and you get an error.
Glenn Balon
Production: NX 12.0.2 MP4 Primarily CAM
