cancel
Check collisions in ISV
Hi All!
How the collision checked in ISV?
I run the simulation, and get an error collision Y_SLIDE and WORKPIECE.
the workpiece is a solid complex configuration.
The distance from the workpiece to component Y is large
During simulation, the same program with a simple workpiece is no error.
What could be the problem?
