Co-ordinate format issue when I am outputting the post in inch mode.
I am facing one issue regarding format, as my post is in "MM" but when I am trying to post it in "INCH" mode only three values are coming after point, but I want four values after point, even if I am changing the word format to AbsCoord_less_in for "INCH" mode still its outputting three values that to rounded one, please help me out in this. Also I observed I , J, K formates are coming fine as per my requirement. PFA screenshot for same.
Re: Co-ordinate format issue when I am outputting the post in inch mode.
If this is Post Builder, create a Units Only Subpost for the inch units.
Mark Rief
Retired Siemens
Thanks for reply mark, I guess when I use this variable "mom_kin_machine_resolution" and set it as 0.0001 for output unit "INCH" in start of program my post is outputting four decimal digits in "INCH" mode.
