cancel
Compare
Why "Compare" function at Verify - 2D Dynamic don't work in NX9?
Is there someone who know where is problem?
Hi,   this is a known problem and will be fixed in NX901....
Sorry for the inconvenience.
Thomas Schulz
Siemens PLM
Re: Hi,   this is a known problem and will be fixed in NX901....
What are you expecting to see with compare?
Why not use thickness by color?
I think this is something you should contact GTAC about - they can look at your part and see if this is not as expected.
Mark Rief
Retired Siemens
