Computer Specs
Hi
 What do do recommend as the best computer graphics card for NX 9, I have adjusted the chordal tolerances for fine resolution as we machine small features down to 50um in size.We have a 4GB GE force GT430 card  at the moment, and some toolpaths are taking a long time to verify. Thanks
I doubt that the graphic card will help much. Which type...
Which type of operation is so slow? Is it 5 axis simultaneously?
You also could try to change the slider setting to 10.
You could try to disable the holder check, that might be improve the situation.
With NX901 there will be a performance fix for holder check and slider setting in material removal.
Thomas Schulz
Siemens PLM
