Contour_Surface Mill
Yesterday I make a practice for a simple model with Contour_Surface Mill. But I have a slight question is little mark in surface after mill ( cause by connection between tool path) Does somebody know how to mill this tool path with no connection? Or like a attached picture 2.
Thanks!
3 REPLIES 3
Re: Contour_Surface Mill
Hi
You should choose different Cut Pattern, e.g. Helical
or
Different Drive Method, e.g. Streamline or Spiral
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
i used Fix contour by spiral
**bleep** de a genera programul de ieșire folosind freza sferica cu centrul de tăiere (punct central instrument), sau vârf tăietor (punct vârful instrument), în NX 8?
mulțumesc!
Sorin Marcu
CNC Programmer
Matrite DACIA-Group Renault
