Contour mill issue
Now I use contour mill to mill 5 aaxis surface. When I use mutiple depth to cut side face. It looks like more engage and retract. I do not know why? Someone knows what it happens?
Thanks in advance!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: Contour mill issue
Try to align your tool axis differently with the contour profile operation.
There are three options available:
  • automatic
  • UV direction
  • along edges
Have you tried each of them and was the result always the same?
share this part, people can only guess what is wrong
Yes, I use three option to play the part. swarf base UV is better than others. But it still not good. I attached the part file please have a look!
Thanks!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
swarf base uv setting in NX11 looks OK
I would also report this to GTAC, so that development can improve the tool path in later releases.
i TEST THIS IN nx11. still not good! Could you sent part back to me.? upload to here.
UG3.0
UG6.0
NX10.0.35
NX11.0.1
Hi @Canateda
I made a few changes to get a more consistent tool path the largest was giving the tool a radius.
Take a look it may or may not be of use?
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Vericut 7.3,7.4.1,8.0.2
@CAM_Jockey
Thanks for your info.
Yes, Now tool path looks good. But I saw you use Dia20mm ball end mill to do this, But I would like to use the end mill to mill. Probably Siemens need improve this.
UG3.0
UG6.0
NX10.0.35
NX11.0.1
Have you tried using a smaller corner radius, so you get a bull nose tool?
As I said before, you need to report this to GTAC to have it fixed in a future release of NX.
