Re: Converting Units
I found out that it appears when using the utilty that it converts the units and the result is in the latest version of NX, I havbe a similar situation with my Vericut BAT file it always loads the latest version of NX although it is set up for an earlier version. I think you are correct in needing the base dir changed but that is not an area I am comfortable dabbling in to find out.
Mike
NX 11.0.2.7
Win 10
