Create BLOCK feature using expressions but position point does not retain expression
I am attempting to create and postion a BLOCK feature using expressions.
I noticed in NX7.5 and NX9 that the BLOCK feature length/width/height has no problems retaining the expressions but the positioning point will not. There is not a problem in the postion point form inputting what expression I want to use manually, but it will not stay.
Is this the proper behaviour?
Shouldn't I be able to handle this all through my expressions?
Thanks in advance, MC
