Create GCODE from outside
Hey everybody,
I try to create a GCODE from outside of NX9 (node js application)
I did a batch file for that who execute the post processsor but I have got an error.
I think it is come from my Visual Studio compilator but I dont find the error.
The MSVCDir environment variable is not set correctly.... you must modify ufvars.bat
If anybody has got an idea it will be helpful for me Smiley Happy
Have a good day
Re: Create GCODE from outside
Is postprocess.bat something you wrote? Be sure the required NX environment variables are defined. For an example, take a look at mach\auxiliary\runugpost.bat. Even if you create your own command line, you need some of the variables defined.
Mark Rief
Retired Siemens
