Create User Definied Tool in 5axis Generic Motion
Hello Community,
i created a user definied tool for my Generic Motion Operation in NX.
My tool shape will always rotated, but i dont need it in this shape. Is there some other options to get my desired 3D tool ? I want some kind of turning tool, but cant use them in Generic Motion....
Re: Create User Definied Tool in 5axis Generic Motion
Esteemed Contributor
Have you looked at 7 or 10 parameter mills? (I think they are in the variable axis template part, not sure about fixed axis contouring)
Would a step drill (holemaking template) work?
Don't be put off by the word "drill" - you can use these tools in milling operations.
If your tool is not spinning, create a solid tool. Start with the tool model, and choose the solid tool template. This is a non-parametric tool - like a probe for example.
Mark Rief
Retired Siemens
My tool is not spinning. I will create my Kinematic with Generic Motion and add 1000 RotatoryVectorPointMoves with Journal. Can you maybe show me in a short video how to create a solid tool for example a qubic 10x10x10 cm as tool model?
One more question:
Is it possible to have more then one cutter in a tool?
Search the help for create solid tool, or look here:
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.1/nx_help/#uid:generic_solid_tool-probe_dialog
It is for a probe, but the process is the same.
Mark Rief
Retired Siemens
Thank you @FROBI and @MarkRief
but my problem is already not solved and i think its more specific.
In those documentations it is described how i can create a tool with ONE cutting part,
but i need al tool with more cutters. Moreover i have to use this created tool in Generic Motion.
See my uploaded picture. Is it even possible to realise this in NX?
Sincerly RickTick
The amount of cutting parts doesn't make any difference, in the end they are all combined into one kinematic group.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
There is example with several cutters in NX library - C:\Program Files\Siemens\NX 10.0\MACH\resource\library\tool\graphics\ugt0202_001.prt
There are 2 different cases where we have part assemblies for tools.
A parametric tool can have a solid assembly representation in addition to the normal definition - such as ugt0202_001.
The other case of for non-parametric tools, that may not be spinning, such as ugt0402_001. There is a completely different workflow to define these, where you start with the tool assembly as your work part. I think this is what the original question was about.
Mark Rief
Retired Siemens
