Create a Tool From a Solid Body
How i can Create a Tool From any Solid Body . i want to design any Profile 3D for Tool on Modeling Application , and i want to add it to Manufacturing to creat Tool Path ? Because my company have alot of Tool for Groove ! Please help me about this problem ...
Re: Create a Tool From a Solid Body
A little research in the old threads, should find what you are looking for.
3D tool
@mkn
Production: NX11.0.2.7,VERICUT 7.3.3
Development: Tcl/Tk, Gnuplot
www.deshors-tiremold.com
you can add and simulate solid tool but generating paths is based on parametric nx tools.
So best way is to have solid body tool matching with the nx parametric tool.
please correct me if I am wrong.
But my company have to manufacturing alot of Slot that have complex geometry , so my tool have to the same profile Slot !
Solid tools can only be used by a very limited set of operations. Parametric tools can be used by a much wider range of operations.
@MarkRiefposted a journal to create parametric tools from solid tools a while back, so you might be able to use that to create a user-defined tool.
@Stefan_Pendl
Do you know where i can find this journal?
The thread is called Sample vb program to create mill holder from curves or solid , sure it is for the holder, but similar is possible for user defined tools.
