Create machine kit automation api missing in journal
Hi All,
I'm trying to learn about the ways to create automations through the nxOpen API.
So I've started with journaling the import NC archive process:
1. I open a .prt file with a kinematic model already entered.
2. I start journaling
3. Click "import NC Archive", see that the archive is imported successfully
4.End journaling
But when I open the journal it seems that some of the code is missing, the file path of the NC archive for example.
Is this nxOpen Api not availiable?
Here is an example of the journaled code
    //   Menu: Tools->Machine Tool Builder->Import NC Archive...
    nxopen.sim.KinematicConfigurator kinematicConfigurator1;
    kinematicConfigurator1 = workPart.kinematicConfigurator();
    nxopen.sim.MachineToolConfiguration machineToolConfiguration1;
    machineToolConfiguration1 = kinematicConfigurator1.createMachineToolConfigurationBuilder();
    nxopen.NXObject nXObject1;
    nXObject1 = machineToolConfiguration1.commit();
    machineToolConfiguration1.destroy();
Re: Create machine kit automation api missing in journal
You cannot record a journal of all actions, the journal indicator tells you what action can be recorded.
You will have to check the NXOpen API reference, if there is a single API function to do this, but I doubt.
BTW, this post would better suite the "programming and customization" forum.
Hi Stefan,
Thanks for the response,
when I start journaling it looks like the action should be able to be recorded
2016-12-27 18_47_27-NX 11 - Machine Tool Builder - [Machine Kit test - 2016.12.27 18_25_33.prt (Modi.pngCould this be an UI issue where it looks like it should be recorded but actually can't?
I would report it to GTAC, so that they can correct it.
Thanks a bunch for you help!
