Creating an MCF with 840D and Basic CCFs
I am attempting to create an MCF from scratch. I have included the 840D and Basic CCFs.  I then added $TOOL to the transformations list and then get the following errors:
I then found a helpful post where Thomas says "You have to copy the entire transformation stack from the CCF to MCF."  https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/Setting-up-840D-ba...
After copying over the stack I am getting new errors.
This makes me wonder if there are any other tricks to using 840D and Basic CCFs in an MCF made from scratch.  Is there a "How To" on the subject?
Thank you,
Jesse
Re: Creating an MCF with 840D and Basic CCFs
Hi Jesse,
about your first problem you found the right solution. ALL transformation need to be copied from CCF to your MCF and then you can start modifying it.
What are the follow up problems?
Thomas
Thomas Schulz
Siemens PLM
You should also pay attention to the order of the transformations. They should be the same as in the CCF file
