Custom member data
Siemens Creator
why I can to do a custom member data?  in the fine finish offset I make the member selection for generate the offset but it does not work,  the image  show the result
Re: Custom member data
Your dialog shows corner conditions, but in the picture it looks like the members are tangent.
In general, custom member data is attached to a boundary member, to do something differently there when generating the path. Usuallyit is for stock or feed, but turning has other options. What are you trying to acccompish with custom member data?
Mark Rief
Retired Siemens
