Customise Dialogebox
Builder
Builder
Is this possible New UI for 10.0.3
Re: Customise Dialogebox
No, sorry. This is the new flat dialog UI which was not available as early as 10.0.3.
Builder
Builder
Is that no any alternative?
Siemens Genius Siemens Genius
Siemens Genius
You can still customize the dialog but you can't make it "flat" as in NX12
Major differences;
  • In the version you use the UI the still use a lot of sub-dialoges, whereas with the flat dialogs the dub-dialogs has been eliminated.
  • The flat dialogs can show the Generate button all the time, whereas the old style only shows on the main dialog.
Best regards
Lars Okkels
Siemens, MBG
Builder
Builder
Can we try by some files of nx 10 replace by nx11 files?
Siemens Genius
Are you asking if you can make the Flat Dialog customization work in NX10 by replacing files from later versions?
No.
Best regards
Lars Okkels
Siemens, MBG
Builder
Builder
Thanx
