Cut Levels Range List missing
Hi All,
I have to NX11 Licenses running. For some reason the dialog boxes do not match. One PC shows a "list"option in the Cut Levels Range In Manufacturing Operations the other does not (see screen shots) any idea how to make all options visible?
3 REPLIES 3
Re: Cut Levels Range List missing
1) Is this the same part / operation in both screen dumps?
If not, use the same part /op (as dialogs can be customized, either by yourself, or by Siemens during upgrades)
2) Are the 2 systems the EXACT same version of NX (including MP)?
3) Could be you have different customer settings betwene the systems.  Try hitting the "gear" icon in the top left, do they both show the same thing?
Hi Ken, the parts were exaclty the same. The solution Hohi88 provided was exactly what I was looking for.
Hit the gear in the upper left corner of the dialog and change to "cut levels more."  I believe that is your problem.
