Cut Region for Roughing
When I determine the Cut Region for Roughing, it's able to detect 2 areas, but when I click Generate, it only detects the lower area, so I have to create another operation for the higher area.
Is there any option that allows it cut 2 different area or more in the same operation?
Thank you for your response!
Hoang
Re: Cut Region for Roughing
Thank you so much, Agrivas!
sorry where I can find this cut region box.
Thanks so much!!!
This box is inside Turning - not milling !
Thanks so much!!!
