Cut level
Builder
Builder
How to set cut level in contour area milling like z level and cavity mill?
(In such a situation, i have to divide face by datum plane, if i do this then all operation gets foul)
Re: Cut level
Hey @Vora,
You can use the Cut Region Manager to define seperate regions. You can also edit in the CRM - Trim, Divide by Holder etc.
Area_Milling.pngArea Milling - Cut Region Manager (CRM)
CRM2.pngCut Region Manager
An older video, but describes the functionality pretty good:
NX CAM - Cut Region Manager
Cheers,
Alexander
Lead Product Manager - Mold & Die
