DESBASTE SIMULTANEO
HOW CAN I MAKE A ROUGH SIMULTANEOUS WITH CUTTER 50MM
Re: DESBASTE SIMULTANEO
Rough with 3 axis cavity mill as much as possible.
Do a contour wall multi axis path and use multiple depth and stepovers.
Dennis Rathi
Creations Unlimited
I just thought of another solution....
Drill a hole in center
Use a ball em with fixed contour > area milling. Start in center and work outward.
Use Tilt tool axis.
Dennis Rathi
Creations Unlimited
this is one of the possible solutions, hope it helps:
create a variable contour operation with a boundary drive, from point as  projection method  and toward point as tool axis method.
You can see the video here:
https://youtu.be/jBynLHtqGCo
have a nice day,
ciao
